Horn does not work. Help.
Old Jul 14, 2003 | 10:12 PM
blkgsr03's Avatar
Default Horn does not work. Help.
hi, my horn does not work. 98 hatch, i checked the fuses n it turned up fine. once in a while when the car is parked in the hot sun when its very hot outside, the horn sometimes works for a little. so i ended up buying a new horn from honda for about $35 bucks. i changed it and it still doesnt work. anyone know wut is the problem here? any help is appreciated. thanks
Old Jul 14, 2003 | 11:45 PM
nimbusnine's Avatar
Just use your finger!! J/K
if you take off your steering wheel there should be a/some copper tabs that may be
worn-dirty or need to be bent back into position. hope this helps.
Old Jul 15, 2003 | 08:00 PM
blkgsr03's Avatar
Default Re: (nimbusnine)
i checked the wires in the steering wheel. the wires are fine. any other places it could be?
Old Jul 15, 2003 | 09:32 PM
Behan's Avatar
Default Re: (CiViC KiD)
did you troubleshoot the wiring? I.E. continuity checks, presence of voltage, etc.
Ldo
May 20, 2009 09:11 PM
qbsi
Jun 27, 2002 07:55 PM
