how do u get TDC?
Old Jul 14, 2003 | 09:44 PM
tangb2023
Guest
Posts: n/a
Default how do u get TDC?
need to know how to get piston to top dead center.. how do u check it to tell.. ??thanks
Old Jul 14, 2003 | 09:49 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: how do u get TDC? (tangb2023)
line the tdc mark on the crank pulley with the timing marks
it's the white mark BTW
Old Jul 14, 2003 | 09:50 PM
4cdfedhatchie's Avatar
for a Dohc or Sohc?
for a Dohc, the word "Top," on both cam gears should face up and the index mark on each cam gear should point to each other in a horizontal position. the index marks should also be even with the level of the cylinder head.
also, the white indicator on the crank pulley should match up with the triangular shaped marker on the lower timing belt cover.
for a Sohc, it is the same thing with the exception of matching the two index markers with each other on each cam gear. instead, the index markers should be even with the cylinder head, as it would be with a Dohc
Old Jul 14, 2003 | 10:16 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
Default Re: how do u get TDC? (4cdfedhatchie)
yeah to do all this though, you have to turn the motor over by turning the crank pulley by way of ratchet and socket. use 17mm for sohc, and 19mm for dohc if i'm not mistaken. turn the crank bolt clockwise until you see the notches line up with the "line" on the plastic cover. there should be a section of 3 notches and then a single notch, the single notch is tdc.... have fun.
Old Jul 14, 2003 | 11:05 PM
tangb2023
Guest
Posts: n/a
Default Re: how do u get TDC? (Emerika)
thanks for the help
Old Jul 14, 2003 | 11:36 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
no prob....
PY2KITR1060
Jul 26, 2022 06:12 AM
Freemananana
Sep 17, 2015 03:43 PM
red rx 91
Mar 5, 2008 03:33 PM
superfuji57
May 16, 2004 03:23 PM
MaxSterling
Jul 9, 2003 06:57 PM
