motor mount inserts???
Old Jul 14, 2003 | 09:33 PM
PoonHunter's Avatar
Default motor mount inserts???
where to get them cheapest? Which brand? How many inserts come with the kit ie just front and rear or inserts for all four mounts? I see summit sells Energy bushings set for $19 but only shows front and rear mounts is that they come with?
Old Jul 14, 2003 | 09:44 PM
'90 ZC REX's Avatar
Default Re: motor mount inserts??? (PoonHunter)
The ES Kit only comes with the Front and Rear Mounts. Check your Stock Mounts to see if they are cracked before you put these in.
My Front and Rear Mounts were in good shape, I have the ES Inserts and All I have to say is if you didnt have Rattles before, you will now.....Vibrates the hell out of everything, but the Motor stays where it is supposed to.
Later,
Mike
'88 CRX "ZC REX"
'99 S-10 Xtreme
Old Jul 14, 2003 | 10:14 PM
blueintegra90's Avatar
go buy a tube of window weld for 10 dollars and feel the holes in with it. i did mine and it works great
Old Jul 15, 2003 | 05:38 AM
keithv's Avatar
Default Re: motor mount inserts??? (blueintegra90)
screw the inserts, do this instead (we-todd is down so the pics don't show up):
https://honda-tech.com/zerothread?id=445236
Old Jul 15, 2003 | 06:14 AM
Charlie Moua's Avatar
Default Re: motor mount inserts??? (keithv)
Yeah that seem like a good idea but my question is this... HOW long will that modifyed mount last? I would hate to due this every freaken 20k or so. If that was the case I would RATHER fork over $15 now for some real poly bushings than saving $10 (24hours down time for it to dry) and end up having to change it out every 20,000 or so miles....
not puting this great DIY mod down just wanna now how effective it is in a long term aspect.
Old Jul 15, 2003 | 07:21 AM
keithv's Avatar
Default Re: motor mount inserts??? (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">not puting this great DIY mod down just wanna now how effective it is in a long term aspect.</TD></TR></TABLE>
i have no clue, so why don't you test it out for us and report back in 20k miles.
Old Jul 15, 2003 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">
i have no clue, so why don't you test it out for us and report back in 20k miles. </TD></TR></TABLE>
LOL maybe someone should to more R & D about this mod. well what ever works for you guys. Keep h-t informed of the longevity of the mounts.
Old Jul 15, 2003 | 10:24 AM
i have had mine made with the window weld for about 2 years now and it still works the same as it did when i put it in. no signs of cracks or nothing
Old Jul 15, 2003 | 10:45 AM
PoonHunter's Avatar
is there anyother brands besides ES..i think I heard a brand called Prothane..is this a good brand? I cant make my own mounts since this is my only car and cant afford 24hrs down time as I work almost every day
Old Jul 15, 2003 | 10:48 AM
Loaded Butane's Avatar
I think Prothane has inserts for all the mounts.
I use the ES inserts in the front and rear mount and I filled in the other 2 mounts with polyurethane sealant and it works great. I have had this combo for over a year now.
Old Jul 15, 2003 | 11:36 AM
silverpenny's Avatar
Mugen motor mount inserts $180 http://www.kingmotorsports.com
Old Jul 15, 2003 | 02:34 PM
PoonHunter's Avatar
Default Re: motor mount inserts??? (silverpenny)
where can I get the prothane set at?
GK2
Jul 13, 2023 12:00 PM
Boner_Ben
May 29, 2007 03:21 PM
Spectrum24x
Jul 6, 2005 10:34 PM
Maengelito
16
Dec 5, 2004 07:07 AM
ragejed
May 18, 2002 06:56 PM
