just got my b18 swap into a 90 civic running but having big probs...
Old Jul 14, 2003 | 07:18 PM
litlekikr's Avatar
Default just got my b18 swap into a 90 civic running but having big probs...
I have a LS motor w/ a b16 trans in my 90 hatch. My problem is that the motor spits and sputters like a b*tch when i give it just a lil throttle, it'll smooth out a bit at around 4-45k but since i have everything brand new, or just about, i don't want to spin the motor this high just to keep it going to were i need to be. I did have some gas in it that has been there for a year so i put some premium in w/ some gas treatment. I'm also running a stock dx cat back system that dumps out about a foot after the cat. My friend was following me home, like 2 miles, and he said the cat and the 1 foot section behind it was glowing red and shooting out flames so we stopped and let it cooldown. i'm also getting a check engine light that blinks 1 time and then the car runs worse. I believe that's the code ofr an O2 sensor. I have a remapped 90 civic si computer in it and will be getting a stock LS computer tomorrow.
Any ideas as to what it may be? i think it's my fuel pump or my fuel filter is straight f'd up. I also had to replace the main relay in the drivers footwell, maybe it went out and fried the pump? i'm getting pissed cause i've had this **** for a year and finally installed it. The car has sat for a year w/ no motor in it.
Old Jul 14, 2003 | 07:22 PM
poison's Avatar
Default Re: just got my b18 swap into a 90 civic running but having big probs... (litlekikr)
Check your spark plugs, and possibly fuel injectors.
You getting any codes?
Check your spark plugs and see waht color they are.
Old Jul 14, 2003 | 07:24 PM
litlekikr's Avatar
Default Re: just got my b18 swap into a 90 civic running but having big probs... (poison)
i plug is normal, 2 are lean and 1 is rich. hmm, possible injector problem?
Old Jul 14, 2003 | 07:25 PM
litlekikr's Avatar
oh yeah, just 1 code. the computer blinks 1 time. The book says it's a o2 code.
Old Jul 14, 2003 | 09:31 PM
97hb's Avatar
Make sure the map and tps are not switched.
Old Jul 15, 2003 | 04:47 PM
litlekikr's Avatar
Default Re: just got my b18 swap into a 90 civic running but having big probs... (97hb)
ok, i removed the cat and gutted it, it was blocked solid causing insane amounts of backpressure. Now that i have taken care of the excessive back pressure, the o2 code is gone. I did have a map sensor code then i put my buddies new sensor on and it went away. I drove it home today but i could not give it more then 1/2 of gas otherwise it just sputtered and went nowhere so i had to back off to about 1/4 gas and it started moving a bit. About 10 minutes into the drive, my check engine light came on and flashes out code 15, igniter problem. My plugs are straight black. I just had new ngk's in there but i don't think the kid gapped them. Also, i have to use some old plug wires due to REAL tight $$$ probs. I will have new ones tomorrow and plugs. What are the possibility's of a code 15? Also, anybody have a top view of a LS swap into a 90 hatch so i can figure out vacuum routing.
Thanx
journeyquest
Apr 3, 2011 07:28 PM
jnguyen100187
May 20, 2007 09:25 PM
elrandeeto
Apr 29, 2006 07:00 AM
B18c5rx
Apr 14, 2005 08:43 AM
d8168055
Feb 28, 2003 09:15 AM
