B16 Burns Oil After 5.800RPM
Old Jul 14, 2003 | 06:21 PM
Psixas's Avatar
Default B16 Burns Oil After 5.800RPM
I have a B16 SiR V-TEC engine on my civic and after 5.800RPM white smoke comes out from the exaust. When its cold it runs fine, but after a while the problem begins and the car looses performance. Someone Help Me ...
Psixas's Avatar
Default Re: B16 Burns Oil After 5.800RPM (Psixas)
pextou re zari
Old Jul 15, 2003 | 08:44 AM
goodbyegti's Avatar
hmm piston rings? try a compression test but first check the PCV valve by lifting it from underneath, if it compresses easy then its ok, if it doesnt you're probably getting an abnormally high crankcase pressure which is causing oil to get forced into the combustion chamber- hence the white smoke...
bradabu
Feb 14, 2011 07:42 PM
EFHATCH88
Dec 29, 2006 01:05 AM
92CivicSiR2
Aug 15, 2004 11:38 AM
slammin86
May 14, 2004 08:20 AM
Vtecuser
Jun 15, 2003 11:48 AM
