93 LX cranks but won't start, probably no spark
Old Jul 14, 2003 | 06:13 PM
StimpyBoy's Avatar
Default 93 LX cranks but won't start, probably no spark
Hiya guys, I hope I have the right area. I'm an Accord owner but I'm trying to help out the family Civic.
The Civic (manual, LX CDN) would occasionally refuse to start, or it would stall out while driving and then refuse to restart for several minutes. Finally one day (I bugged them to get it looked at, but you know family...) the car refused to start altogether. It cranks but won't start.
Right now, the car will crank but it won't start. I replaced the main relay and the fuel filter, and the plugs smelled of gas so fuel delivery seems to be good. Previously, I held a screwdriver in a plug boot and held the screwdriver over a ground and I saw arcs. I swear I did! Now I don't see any arcing at all. I'm going to try a plug out of the block next to look for spark. I replaced the wires, plugs and the dist cap/rotor while trying to fix it. The grounds around the area look fairly decent. All the fuses look fine, including the ECU and backup fuses.
From searching and such, it sounds like either the igniter coil or the igniter or both may be bad. Any help would be greatly appreciated, especially on how to test those two. Can they be tested at automotive stores?
The tl;dr: Car will crank but won't start, used to stall and wouldn't restart for several minutes. Replaced fuel filter, main relay, plugs, plug wires, and dist cap/rotor. Is it likely the igniter/coil?
Old Jul 14, 2003 | 07:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 93 LX cranks but won't start, probably no spark (StimpyBoy)
take off the cap and see if there is any rust, chances are you need an ignitor or coil.
Old Jul 14, 2003 | 07:22 PM
StimpyBoy's Avatar
Default Re: 93 LX cranks but won't start, probably no spark (boostedcivicsir)
There was uber amounts of red dust inside, I'm guessing that's rust. So it looks like a new ignitor or coil. Alright then.
Old Jul 14, 2003 | 08:50 PM
vulgar_si's Avatar
I had something like tht with my car. Ended up being the disrtibutor. I would say that you are on the right track. Just make sure you have stuff tested before you replace it. Things get real expensive if you don't.
Old Jul 14, 2003 | 08:55 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">take off the cap and see if there is any rust, chances are you need an ignitor or coil.</TD></TR></TABLE>
why dont you jus try replacing the distubutor cap and rotor first?
did i spell dustubutor right? i dont think i did
Old Jul 14, 2003 | 09:05 PM
Neptune's Avatar
Check your ecu see if it is throwing a code. May be a sensor too.
Bienval23
Aug 18, 2014 12:14 PM
oakpwr
Jan 20, 2007 06:00 PM
chinese buffet
Jul 16, 2006 05:09 AM
nylshatch
Nov 28, 2005 06:29 PM
hybridreams
Nov 24, 2003 09:18 AM
