crank ?'s
Old Jul 14, 2003 | 04:47 PM
88hondahatch's Avatar
Default crank ?'s
ok as most of you know, i spun a bearing in my GSR motor, i might be getting ITR pistons, while my motor is apart. but i need a new crank. ive heard rumors of an LS crank bumping compression slightly. if i buy the ITR pistons will i be able to run the LS crank? should i just stick w/ a GSR crank?
Old Jul 14, 2003 | 06:02 PM
skribblah's Avatar
Default Re: crank ?'s (88hondahatch)
LS crank increses DISPLACEMENT.and yes you can use ITR pistons with LS crank. just check for clearances.
Old Jul 15, 2003 | 12:55 AM
lilblacksol's Avatar
Default Re: crank ?'s (skribblah)
well fromdifferent arguements on here I hear that you must mod your squirters to use a ls crank.....some say they had to and some din.I dont understand it! wante to do it but never got a positive answer about it.....
Old Jul 15, 2003 | 04:12 AM
Tbone's Avatar
Default Re: crank ?'s (lilblacksol)
You need to run ls rods as well.
Old Jul 15, 2003 | 07:03 AM
Default Re: crank ?'s (Tbone)
i think i'll just stick with a GSR crank, thanks guys
1SLaMMeDC2
Jul 22, 2010 10:14 AM
joedeezy
Oct 18, 2008 02:53 PM
CIVICSI12
Sep 19, 2006 06:02 PM
Art701
Mar 19, 2003 06:47 AM
