when setting a hp goal like 300whp... a few questions about turbo choice
Old Jul 14, 2003 | 03:22 PM
Mr. Softee's Avatar
Default when setting a hp goal like 300whp... a few questions about turbo choice
would it be better to chose a turbo that is larger (like a t3/60-1) and has room for more power, (even tho you will never make that much power )
or to choose a turbo that maxes out exactly at 300whp. or just slightly above.
sam
Old Jul 14, 2003 | 03:24 PM
ekb18c's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (94goldjungsr)
t3/60-1 is a good choice for 300whp... You'll have a easier time achieving that power with a t3/60-1. Besides boost is so addictive you can't say 300whp is all you want. You will want more later, trust me.
Old Jul 14, 2003 | 03:26 PM
Mr. Softee's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (ekb18c)
Im well aware. I boosted my teg last summer. Keeping this alive for more opinion and some technical insight im lacking.
Old Jul 14, 2003 | 03:34 PM
R@mon's Avatar
i would go with a larger turbo for a couple of reasons:
1: easier to reach your hp goal
2: colder intake temps
3: wont have to upgrade
4: better top end with a larger turbo
5: lag will help on the street
Old Jul 14, 2003 | 05:41 PM
Quick 200k Mile Motor's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (93h22a4)
generally, a larger compressor doesn't need to spin fast to produce boost (doesnt heat the intake charge as much) but the size still has to be efficient (at least 65% ) for operation within peak tq & hp.
I wouldn't touch the T3/60-1
Id rather go with a T04E ..thats just me
Old Jul 14, 2003 | 05:55 PM
Foozball26's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (Quick 200k Mile Motor)
bigger turbo + less boost = less torque
go with a t3/to4e, 300 whp is cake for that turbo
no need for a 60-1 and lag your *** off so you can run 1-2 lbs of boost less.
Old Jul 14, 2003 | 06:14 PM
intekragsr's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (Foozball26)
[/QUOTE]
a .60 trim that is
Old Jul 14, 2003 | 11:35 PM
Foozball26's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (intekragsr)
yup no doubt.
Old Jul 15, 2003 | 05:26 AM
Overblown-Teg's Avatar
Pick a turbo that is efficient at 300hp. You can go lots of places and look at compressor maps and see which one will work best for you.
Old Jul 15, 2003 | 05:42 AM
quikB18B's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (Overblown-Teg)
Dont geta big turbo that you wont utilize. You can make close to your goal on 8-9 psi with hondata, my recomendation goes to t3/t04e, or go with precision if you got the $. Im going with the sc34 right now its getting utilized next to my bed
Old Jul 15, 2003 | 05:46 AM
PM-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">
a .60 trim that is [/QUOTE]
true dat , thats what im running and its a great turbo .
Old Jul 15, 2003 | 06:34 AM
ebp 99 si's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (itr206)
i'm using a t3/t04e 60 trim, .63ar w/ stage 5 wheel on hondata and 10lbs boost
hopefully with a decent tune i can get 300whp
Old Jul 15, 2003 | 08:52 AM
Jefnes's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (ebp 99 si)
for 'Only' 300whp. look at a compressor that does the 'job'
and thats it.
You aren't goign to run 1000cc inj so you'll have the fuel for
a 'later' upgrade.
Pick the turbo, and the rest of your components to meet a
a common goal. Why have a 400hp turbo and 300hp worth of inj?
Or why have a 400hp turbo and a 2.25" exhaust?
Or why build in 'lag' when you don't have to?
Try a t3/to4E:
Look at the 46 trim or 50 trim compressors. (sure they won't make 450, but 300
is what they were 'made' for)
Turbine side: look at stage a stage 3 wheel in a .48 or a.63 housing. (the buick GN uses a .63 up past 400whp)
Hell, if you only wanted to ~210whp Id say go for a T25... full boost at 2200 is
not so bad....
Rememebr its about the AREA under the curve that matters....
Jeffrey Atwood BSME
Old Jul 15, 2003 | 08:59 AM
Short Round's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">bigger turbo + less boost = less torque
no need for a 60-1 and lag your *** off so you can run 1-2 lbs of boost less.</TD></TR></TABLE>
300 whp/270 wtq @ 12.5 psi, bone stock b18b
Old Jul 15, 2003 | 06:15 PM
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (Short Round)
yo 94gold, i got ur IM but i can't reply, they are like broken or something
it was on a 57 trim t3/t04e, part of the max rev kit, 60 compressor, 63 exhaust w/ the maxrev 2.5 dp and carsound cat, with 3" cat back
Old Jul 15, 2003 | 08:27 PM
Mr. Softee's Avatar
cool. thanks for info.
Old Jul 16, 2003 | 10:32 PM
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">go with a t3/to4e, 300 whp is cake for that turbo. a .60 trim that is </TD></TR></TABLE>
Yup, I am running at 7 PSI now and it feels great... 300whp easily down the road, I have the same goal. 300whp daily driver with room to grow once I get a built bottom end
Old Jul 17, 2003 | 05:13 AM
2lowintegra's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (mskibbz-T)
Jefnes - great advice man!!! i see way to many people using massive turbo's that don't need them.... these same people would run faster 1/4's with smaller turbo's...
here's a perfect example... my buddy with a soch vtec eg put on an IHI 25 turbo from a probe and ran 14.0 @103mph on friday night..... and then another buddy of mine who has a b16a civic with a t3/t04e 60 trim .63 a/r ended up spinning through 1st and 2nd (with drag radials). and pulled a 15.0 on his BEST run.. he even had a couple runs in the 16's....
Old Jul 17, 2003 | 09:05 AM
LEON's Avatar
Default Re: when setting a hp goal like 300whp... a few questions about turbo choice (2lowintegra)
It sounds more like your buddy cant drive... but I get your point.
93first1
Apr 5, 2006 05:12 AM
riceburnah
Jul 14, 2004 08:02 PM
bottlefedintegra
Dec 12, 2003 06:17 PM
egg
May 2, 2003 04:30 PM
