ls-vtec gasket and belt question!
I am ready to assemble my built LS bottom end going into my 99 SI. I am going to order my timing belt and water pump.
My question is: I have a b16 waterpump, a gsr timing belt will work with a b16 waterpump correct? or do i need a gsr waterpump?
Also I am trying to order the dowel pins for my z10 block girdle. What are the dowel pins i need to order?? I have heard that u can find them in a crv transmission, are they found in a gsr motor aswell? The parts guy at acura wasnt sure, there were two different dowel pins showing up and we werent sure which would work.
any help is appreciated
You will need (2) 94301-12200 and (4) 90715-PC6-000 dowel pins. Make sure that the crank turns smoothly with the mains torqued, the girdle can cause the main bearing caps to become mis-aligned, which will require align boring.
When i had my block bored, I gave him my main caps and he aligned bored it. You think there will be a problem with the girdle on?
03EM2guy
Aug 27, 2010 07:11 PM
CivSiClone_96
Nov 24, 2009 05:06 PM
