Timing belt broke, possible bent valve?
I have a 90 accord dx, f22a. Water pump seized, broke timing belt, possible bent valve. I'm not sure if valve is bent yet. If one is, should I replace all the valves at the same time? Does any one know where to find directions, any tips?
If you replace the belt/water pump without checking the valves first, use a compression tester to check each cylinder. Otherwise, you may try a leakdown to determine how many valves are bent without the timing belt on. Probably time for an H22.
It's not a possibility. The Accord and Preludes have interference engines which means if the timing belt snaps or slips off, then you're not worried about bending a valve, you're worried about how many you bent. Only way to find out, compression check or pull the head. Either way you'll find the same scenario...bent valves.
Charlie Moua
Dec 15, 2009 06:16 PM
