Is this amp any good (Alpine) / what power subs and fronts could it power?
Alpine V12 Expert Series
MRV-F305: (4/3/2 Channel Model)
- RMS Power at 12V, 20 Hz- 20 kHz; 30W x 4 (into 4 ohms, 0.08% THD); 40W x 4 (into 2 ohms, 0.3% THD); Bridged: 80W x 2 (into 4 ohms, 0.3% THD)
- RMS Power at 14.4V, 20 Hz- 20 kHz; 50W x 4 (into 4 ohms, 0.08% THD); 60W x 4 (into 2 ohms, 0.3% THD); Bridged: 120W x 2 (into 4 ohms, 0.3%)
- Top Panel Adjustment of Crossover and Gain
- Top Panel Power LED
- MOSFET Final Stage
- DC Straight - Discrete Preamp Stage
- Special Preamp Power Supply
- Star Circuit - Noise Elimination Coil
- Input Mode Selector - 4V Staight Input Selector
- Non-Fading PreOut
- Gold Plated Terminals
Also, any idea on what its worth?
Brand new from a store your looking at probaly 200- 250. What do you want to push front, rears, and sub all in 1? Or just fronts and sub? And whats your budget?
Im looking for the cheapest stuff that I can use that will sound decent. Is that amp powerful enough to power fronts rears and sub or would it be better to just go with fronts and sub? (I got the amp from someone who owed me money, so I want to use it if its any good)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">That will be a great amp
I have an MRV F405 (the same only bigger) and a 1005 (same series, looks the same) and they are brilliant.</TD></TR></TABLE>
That reminds me, that series of amps run really hot.
I.E you won't be able to touch it and it might melt your floor mats if you put it too close. Don't let that put you off though, mine have been in for over 2 years with no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">That reminds me, that series of amps run really hot.
I.E you won't be able to touch it and it might melt your floor mats if you put it too close. Don't let that put you off though, mine have been in for over 2 years with no problems.</TD></TR></TABLE>
Mine's never gotten very hot at all. But then again I'm not pushing it all that hard. Only running a 4ohm load.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic »</TD></TR><TR><TD CLASS="quote">I've never heard the type x's how are they? how much power are you giving them?</TD></TR></TABLE>
well i haven't completely finished my installation of them so right now they're running free air where i'm going to build the kicks. they do sound very nice actually, great tonal balance, the highs are clear without being overpowering. My only complaint i have about them is they're a little lacking on the midbass but that could also change with a sealed enclosure.
as far as power, i'm running them bi-amped off my MRV-F340 which is 65 X 4 but i have the gains set a little lower for the tweeter.
