CV joints
Old Jul 14, 2003 | 06:17 AM
Black_Accord's Avatar
Default CV joints
I just had my left axle replaced because the cv boot tore causing the joint to go bad. I had that same axle replaced about 5 months ago. Should that axle have lasted longer or is it just luck of the draw? I don't beat on the car although my commute to school does involve some rough back roads. I just want to know if I should bring this up when I go to pick up my car later. Thanks.
Old Jul 14, 2003 | 06:31 AM
paul9luap's Avatar
Default Re: CV joints (Black_Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black_Accord &raquo;</TD></TR><TR><TD CLASS="quote">I just had my left axle replaced because the cv boot tore causing the joint to go bad. I had that same axle replaced about 5 months ago. Should that axle have lasted longer or is it just luck of the draw? I don't beat on the car although my commute to school does involve some rough back roads. I just want to know if I should bring this up when I go to pick up my car later. Thanks.</TD></TR></TABLE>
Yeah, defintly bring it up. There should be a warranty on the labor/parts. I had the same problem acouple of years ago. I was in an accident, and the shop had to replace the entire left front suspension. Well, 6 months later, my cv boot cracked, causing all the grease to drain out, eventually ruining the new driveshaft they had put in.
Old Jul 14, 2003 | 08:08 AM
urbanlegend21's Avatar
New User
Default Re: CV joints (paul9luap)
see this is the problem
new axles are $75 when you buy them rebuilt, it costs less for the shop to buy the new axle and put it in than take an old one, clean it out completely,(once you get dirt and brime in the bearings they are done), put a new boot on, put it in to only last half the time of a new one
they are not jipping you any money
aleks77
Dec 8, 2010 07:10 AM
crashingtones
Sep 28, 2008 11:11 PM
ahloung
15
Mar 14, 2006 11:52 AM
b20integrapower
Feb 15, 2006 07:57 PM
S.Celia
Jan 26, 2004 07:24 AM
