turboing my 92 integra
i am going to run 10psi of boost and i am wondering if my stock rods will hold? and i just purchased crower stage 2 cams will they help or hurt? also i plan to buy je pistons.ne one have advise
pistons usually go first so rods should hold.
Cams are fine, just have tuner dial out overlap as much as possible. Switch to type r lost motion assemblies or you may break your cam.
Pistons, go with around 9.5 or 10 flat compression. I personally like 10.
The rods will probably hold.
You have an LS right? You'll have a difficult time installing R lost motion assemblies if so. If I was you I'd just sell the cams. But I'm not you.
