So what do u guys use to gap ur rings??
Old Jul 14, 2003 | 05:51 AM
TheSwift1's Avatar
Default So what do u guys use to gap ur rings??
I tried a search, but couldn't find anything on them...
SO what do u guys use to gap ur rings? just a file? i remember a post a while back that had an inexpensive little ring gap grinder that i belived hooked up to ur drill or sumthin like that...does anybody know where i can find something like that?
thanx..
Old Jul 14, 2003 | 08:27 PM
TheSwift1's Avatar
Default Re: So what do u guys use to gap ur rings?? (TheSwift1)
ttt...i know someone knows!
Old Jul 14, 2003 | 08:29 PM
Flamenco-T's Avatar
I use a normal file from home depot. One thing you need to keep in mind is that make sure that you take out th sharp edges out of the surface you just grind and smooth it out...grind it to the gap that you want, then smooth out the edges.
By doing this, the ring will not "Stuck" in the grooves as it trying to expand.
stan
Old Jul 15, 2003 | 01:22 AM
paulzy's Avatar
Default Re: So what do u guys use to gap ur rings?? (Flamenco-T)
I have a ring filer from Summit, but I have used a flat hand file before....
remember you want teh gap liek this "/ \"
Old Jul 15, 2003 | 03:22 AM
Farnsrocket's Avatar
Default Re: So what do u guys use to gap ur rings?? (Paul_Vang)
I used a small Swiss file I bought at a Sears.
Old Sep 21, 2003 | 09:29 AM
crxhybrid1320's Avatar
Why should the ring gap be like that "^". Posted above. I would thing it would be sraight gap so when it expans it comes perfectly together like this "II".
Old Sep 21, 2003 | 10:34 AM
boostaholic's Avatar
Default Re: So what do u guys use to gap ur rings?? (crxhybrid1320)
I use a benchtop mounted rotating ring filer too. Any good file should work just as well, just make sure to debur the edges after you file them.
imadigitalgod
Audio / Security / Video
Dec 26, 2009 10:27 PM
Trixiem
Suspension & Brakes
Oct 9, 2005 05:43 AM
MidShipCivic
Mar 17, 2005 09:33 PM
Anthrax-VX
Apr 26, 2004 05:48 PM
