will this affect tire ware?
Old Jul 13, 2003 | 09:58 PM
AzntaggeR's Avatar
TSPeed Factory
Default will this affect tire ware?
i just got done fixing the negative camber on my rear wheels with the nut and washers idea. well, i bought 4 hex bolts but when i got home i noticed i bought a different size hex bolts (3 correct hex bolts, 1 incorrect hex bolt) . it was too late to go return it to the hardware store, because it had already closed. knowing i had to drive the next day; on the passenger side i used the hex bolts with 6 washers and the other bolt i used only 4. because there are 2 less washers spacing it out will this affect tire ware in any way? or is this not a good idea to drive around on? because the stock bolts are shorter then the new ones i bought.
Old Jul 13, 2003 | 10:09 PM
Pho Real's Avatar
Default Re: will this affect tire ware? (AzntaggeR)
uuhhh
Old Jul 13, 2003 | 10:45 PM
screech's Avatar
Default Re: will this affect tire ware? (Pho Real)
if its not the same on both sides i would imagine it wont wear correctly?
btw how do you fix negative camber by shimming and how much did you drop your car cuz if its dropped its not negative camber.
Old Jul 13, 2003 | 11:22 PM
M-EJ1's Avatar
Default Re: will this affect tire ware? (screech)
So drive on it for tomorrow then go back and get the right bolt you need tomorrow at the hardware store. Not a big deal... one day with some negative camber on one side isn't going to wear out your tires. You probably won't even feel the difference.
Old Jul 13, 2003 | 11:25 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: will this affect tire ware? (M-EJ1)
alright, i thought so too...just had to make sure
Old Jul 14, 2003 | 07:54 AM
ej0513's Avatar
you prolly dont want to because your rear toe will be less on one side (right) and your car just may go down the street sideways.
Old Jul 14, 2003 | 11:26 AM
Esoterikos's Avatar
i'd like two of whatever screech is smokin...i dropped my car 1.8" in the front, and now i've got 2 degrees of negative camber...i also dropped my tiburon and have negative camber on that as well. a friend of mine and i aligned his CRX that he dropped and he had negative camber, too. hmm. damn jap crap...wait, the tib's korean crap...damn asian cars.
lil k
May 19, 2003 12:22 AM
State_of_mind
Jan 15, 2003 12:35 AM
Fuster_Cluck
17
May 17, 2002 10:43 AM
fcuked
10
May 8, 2002 09:18 PM
Fuster_Cluck
Apr 14, 2002 11:37 AM
