tach?
Old Jul 31, 2001 | 06:30 PM
89hondarex's Avatar
New User
Default tach?
i need help to hook up my tach in my 89 si, i know how to hook up all the wires except the one wire that goes to the coil, thanks
Old Jul 31, 2001 | 11:01 PM
89hybrid's Avatar
Default Re: tach? (89hondarex)
you can do one of two things either hook straight to the neg. coil which is inside the dist. or hook it to the blue tach feed actually it would be a splice since you need the wire to be connected in order for the car to run.
Old Jul 31, 2001 | 11:24 PM
raene's Avatar
I hope this helps too.
http://B16A.honda-perf.org/cluster.html
Old Aug 2, 2001 | 12:06 PM
B16A1-EF9's Avatar
Best thin to do is run that wire directly in the engine bay. Splice in to that blue wire coming from the distributor. You'll get a more accurate reading from there. The blue wir is coming out of the distributor and is next to the black wire. There is two connectors on the distributor, you want the blue wire coming from the connector that only has two wires on it.
Hope this helps!
Old Aug 29, 2001 | 09:42 PM
guchiew's Avatar
New User
Default Re: tach? (bandit_sir)
How do you get the wires through the fire wall? There is this plug thingy that I see with wires going through it. Is that it? I tried to pry it off, but it won't budge. If that is the right hole, is it wise to cut off the rubber part?
[Modified by guchiew, 6:43 AM 8/30/2001]
Kingpho
Apr 1, 2012 05:48 AM
97grnrs
Jan 11, 2006 07:32 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
b18c5ivic
15
Sep 15, 2002 06:21 PM
vrrodri
12
Jul 4, 2002 08:19 AM
