Car is stuttering, hesitating, I need help
Old Jul 13, 2003 | 11:05 AM
sydag5's Avatar
Default Car is stuttering, hesitating, I need help
Figured I would post this in here also, because this is where I spend most of my time. My car started to stutter a couple of days go. Now it is getting really bad. It did it about four months ago and I found that it was a starter ground so I tightened that and it solved the problem. Now it is doing the exact same thing. And I have no idea what it could be. I'm pretty sure it is electrical because when it happens the speedometor and the tach start to jump around like crazy. I haven't really checked anything except for the motor grounds, starter ground, and alternator ground, and those are all fine. The only thing that i've done different is change out the plugs but that was like 2 weeks ago and this problem just started a couple of days ago. What else should I check? Plugs, dist. cap, rotor? It is getting on my nerves. I have a 98 civic dx with a boosted b18b. Everything is pretty much stock. Stock ignition and all of that. Anyone have any ideas?
Old Jul 13, 2003 | 11:14 AM
sydag5's Avatar
Default Re: Car is stuttering, hesitating, I need help (sydag5)
top
Old Jul 13, 2003 | 12:05 PM
sydag5's Avatar
help
Old Jul 13, 2003 | 02:16 PM
sydag5's Avatar
problem solved
Old Jan 23, 2004 | 01:43 PM
nevin's Avatar
what was it?
Old Jan 23, 2004 | 03:03 PM
92HB_HB's Avatar
Default Re: Car is stuttering, hesitating, I need help (nevin)
i'm curious to know too...
Old Feb 2, 2004 | 10:47 AM
sydag5's Avatar
Default Re: Car is stuttering, hesitating, I need help (92HB_HB)
starter came loose. Just tightened it back up
NYSItuner
Sep 16, 2007 10:08 PM
chazsi
Apr 20, 2007 11:43 AM
ballerchild
13
Sep 22, 2006 08:04 AM
sydag5
Jul 14, 2003 10:40 AM
gsrintgra98
Feb 22, 2003 03:05 AM
