Problems in a JDM Type R Cluster swap! Help!!!!!
Old Jul 13, 2003 | 09:50 AM
joedr's Avatar
Default Problems in a JDM Type R Cluster swap! Help!!!!!
Hi!
I installed a JDM ITR Cluster and went pretty straight forward as far as installation is concerned.
But, once I started the car I noticed some problems on my cluster.
1. The fuel gauge does not work or does not show any movement even when my car has some gas on it.
2. The temperature cluster goes to the "H" (like super hot) as soon as you put the switch on.
3. The Seat Belt light does not goes out when you buckle up.
Any help on this or a website that shows how to re-wire the cluster cables to fix it?
I'm pretty sure is a wiring problem.
Old Jul 13, 2003 | 09:54 AM
Bbasso's Avatar
Default Re: Problems in a JDM Type R Cluster swap! Help!!!!! (joedr)
Oh did you get the JDM wiring harness too???
J/k
Old Jul 13, 2003 | 10:01 AM
joedr's Avatar
Default Re: Problems in a JDM Type R Cluster swap! Help!!!!! (Bbasso)
Hey!
Nope! I did not! Any help?
Old Jul 13, 2003 | 10:04 AM
Dave-ROR's Avatar
I covered this like 15+ times at least. There are a few ways to do it, so I'll give you the answer but you'll have to search for the details. Swap the gauges to the USDM housing or swap the motherboards.
Old Jul 13, 2003 | 10:08 AM
Saga's Avatar
For a 94-97 integra, jdm 94-97 cluster = plug and play, 98+ cluster = you need to swap all the gauges from the jdm cluster to ur stock cluster.
For a 98-99 integra, jdm 98+ cluster = plug and play, jdm 94-97 cluster = swap the gauges.
For a 00+ integra, swap the gauges.
Old Jul 14, 2003 | 02:22 AM
Aoi-Zip's Avatar
or you can simply swap the films from the clusters around...
Old Jul 14, 2003 | 09:44 AM
threatcon13's Avatar
New User
Default Re: Problems in a JDM Type R Cluster swap! Help!!!!! (Aoi-Zip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aoi-Zip &raquo;</TD></TR><TR><TD CLASS="quote">or you can simply swap the films from the clusters around...</TD></TR></TABLE>Thats what I did (99 jdm itr cluster into 01 gsr) and it worked fine. (swapped out the green film on back)
Old Jul 14, 2003 | 02:43 PM
MiraiZ's Avatar
Default Re: Problems in a JDM Type R Cluster swap! Help!!!!! (Threatcon13)
do a search for Spoon under my name...you"ll find the post valuable
Old Jul 14, 2003 | 02:53 PM
baonest1's Avatar
Default Re: Problems in a JDM Type R Cluster swap! Help!!!!! (MiraiZ)
i just did this on a CDM cluster i have. everything works. (as far as i know)
Old Jul 16, 2003 | 04:50 PM
importrule's Avatar
uhh.. could the wiring for the gas gauge and the temp gauge be.. swapped?
Outkast_CL9
Jul 31, 2004 09:38 AM
funkyfreshdj
May 30, 2004 06:02 PM
88rexboy
Mar 31, 2004 08:42 AM
JjuuN R
Jan 9, 2004 04:32 PM
ApexiR222
Mar 22, 2002 09:43 AM
