BRAKE indicator stays on after parking brake disengaged. What's wrong ??
Old Jul 13, 2003 | 08:55 AM
iperez's Avatar
Default BRAKE indicator stays on after parking brake disengaged. What's wrong ??
Guys, this morning when I left the house I noticed that my BRAKE indicator stayed on after I disengaged the parking brake. The light would come off when I pressed the brakes and back on when I released the brake pedal. What's weird is that the problem went away after a few minutes of driving. I know my front brake pads are needing replacing soon but I mt rears are fine. What could the problem be ??
Old Jul 13, 2003 | 09:01 AM
Hondatec38's Avatar
Default Re: BRAKE indicator stays on after parking brake disengaged. What's wrong ?? (iperez)
Your low on brake fluid in the master cylinder probably. Just top it off a little bit and have your front pads replaced.
Old Jul 13, 2003 | 09:04 AM
thk's Avatar
thk
Members Only
Default Re: BRAKE indicator stays on after parking brake disengaged. What's wrong ?? (Hondatec38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 &raquo;</TD></TR><TR><TD CLASS="quote">Your low on brake fluid in the master cylinder probably. Just top it off a little bit and have your front pads replaced.</TD></TR></TABLE>
If that doesn't solve it, replace the master cylinder cap.
Old Jul 13, 2003 | 06:50 PM
Hondatec38's Avatar
Default Re: BRAKE indicator stays on after parking brake disengaged. What's wrong ?? (thk)
Thank you for adding that. I forgot .
Old Jul 13, 2003 | 06:54 PM
oryanh's Avatar
You may not need to replace the cap...
Just slide the level indicator thingy on the cap up an down a few times.
I think after a few months it tends to get sticky.
Old Jul 14, 2003 | 04:56 AM
iperez's Avatar
Thanks for the info !! I will check it out.
Old Jul 14, 2003 | 09:36 PM
gary201147's Avatar
I had that problem, just take it to the dealership, its under warrenty.
hteg12
Jul 18, 2013 05:13 PM
chris3k
Nov 2, 2008 08:05 PM
tazz29
Jul 9, 2008 10:52 AM
s10cky
17
Dec 20, 2006 07:19 PM
hnz28sjz
Jul 30, 2005 04:50 AM
