Dart Block
I am thinking about getting a dart block, but I have a few ?'s first. Do they have one for the B18C1? I guess it would be the short deck big bore one. It just says dart block for B series motors. I didnt know if all would work or what? If I buy the block I am going to get new bearings. Using the sheet from Honda to find the right bearings, what would I use when it asks for the code off of the block? Does anybody recommend any other bearings to use other than Honda that are the same or better? Thanks
its a B-Series Block..meaning, B18A/B/C/D/E/F/G..whatever you want it to be..! its based off the GSR block..so you can slap on a VTEC head and wont have to run an external oil line.
Dart block only comes with the Block, Main Caps, and Main Cap Bolts (thats it!).
You need Crank, Rods, Pistons, Bearings, Rings, Oil+Water Pump, Windage Tray, Oil Pick up, Oil Pan, and all the bolts, etc....
you might want to do a little SEARCHING before you jump into this..its a great block but...good luck.
Si Integra
Jun 17, 2005 03:25 PM
