H22 punched to 2.5
Old Jul 31, 2001 | 12:31 PM
01-0338R's Avatar
Default H22 punched to 2.5
Have any of you heard or experinced with boring out a 2.2 to a 2.5? Also who makes pistons this size besides JE? Thanks
Old Aug 1, 2001 | 05:19 AM
Merlin1o's Avatar
New User
Default Re: H22 punched to 2.5 (JDMkoupe)
i'm thinking R&D makes a 2.2 that they have stroked to a 2.6, you'd have to do quite a bit of boring to get it that high. although for the street setup i'm thinking R&D suggests no larger than 2.4, that kit includes crankshaft, rods, and pistons i'm thinking.
Old Aug 1, 2001 | 05:49 AM
Lewd Lude's Avatar
Default Re: H22 punched to 2.5 (Merlin1o)
i'm thinking R&D makes a 2.2 ......although for the street setup i'm thinking R&D suggests no larger than 2.4, that kit includes crankshaft, rods, and pistons i'm thinking.
you do quite a lot of thinking now dont you?
Old Aug 1, 2001 | 08:25 AM
JG Luder's Avatar
Default Re: H22 punched to 2.5 (overdose)
hahaha.. I went to a 2.4. That's about as big as you want on a street application. 2.5 (90mm bore) is WAY thin on the cylinder walls. Actually, you don't ahve cylinder walls between the pistons, you ahve to notch the sleeve to get them to all fit against eachother.
Old Aug 1, 2001 | 08:26 AM
JG Luder's Avatar
Default Re: H22 punched to 2.5 (JG Luder)
well, let me rephrase that. I went from 87mm (2.157l) to 89mm (2.35xl)
And Arias will make you some pistons.
Old Aug 5, 2001 | 06:13 PM
importperformance4U's Avatar
New User
how much did it cost to get your engine work done?
Old Aug 6, 2001 | 04:00 PM
01-0338R's Avatar
Default Re: H22 punched to 2.5 (importperformance4U)
Nice setup JG luder, I was thinking of punching a 1.8 to a 2.0? But then i started thinking of doing it to a 2.3. This would be going into a Civic coupe. What kinda of #'s are you putting down? Thanks for the info.
Old Aug 7, 2001 | 05:02 AM
Merlin1o's Avatar
New User
yeahi read the article the day before i read this post, so i was trying to remember exactly what i read.
Kobane
Apr 27, 2008 09:49 AM
crxrich_kid
Feb 21, 2004 01:25 PM
margaflow
Jan 27, 2003 06:56 PM
GSteg
Sep 19, 2002 06:34 PM
