tranny problems, need HELP A.S.A.P
Old Jul 12, 2003 | 03:23 PM
silverpenny's Avatar
Default tranny problems, need HELP A.S.A.P
i was leaving my house the other last night, went to put it in gear and its like its in nutural. i've had a bad axle for like 600miles now and i was wondering if thats the problem or if it could be the ring-n-pinon. i need help fast, thanx.
Old Jul 12, 2003 | 03:30 PM
SIRX's Avatar
Default Re: tranny problems, need HELP A.S.A.P (silverpenny)
check your axles and see if you had one let go. jack the car up put it on stands. with the car in gear see if you can turn a tire freely. If you can turn one easily you probably have a bad shaft. also once shafts start getting bad and are continued to be driven on sometimes they will pop outta the trans. a little checking under tha car will answer all your questions
Old Jul 12, 2003 | 03:36 PM
Default Re: tranny problems, need HELP A.S.A.P (SIRX)
i jacked up the car and took the tire off of the bad side, i held the shaft and turned the wheel and the axel turns all the way in to the tranny.
Old Jul 12, 2003 | 04:36 PM
some one has to know somthing!
Old Jul 12, 2003 | 05:34 PM
CimorelliCRX's Avatar
If the axle is outta the tranny the car will feel like its in neutral and will not put any power to the ground. Check and make sure its still snug and in the tranny. Check both sides, because axles are weird, if you turn right and you hear the axle noise, then its your LEFT axle thats bad, and vice versa, or it oculd be both, but check both and double check. More likely than not its an axle problem.
Old Jul 12, 2003 | 08:04 PM
Default Re: tranny problems, need HELP A.S.A.P (CimorelliCRX)
i don't think it is cuz there still snug in the tranny.
Old Jul 12, 2003 | 11:52 PM
bed time bump
Old Jul 13, 2003 | 05:04 PM
I8ayellowcrayon's Avatar
You say they're in snug... If you can pull one out without doing any twisting, then its not in there. You have to twist the axle in to get it to stay. If thats the case, then you may need a new spring clip or whatever. I couldn't find one, so I had to bend that one back into shape. I thought my tranny was screwed up too, but it was just the passenger side axle coming out...
Old Jul 13, 2003 | 06:59 PM
Default Re: (I8ayellowcrayon)
thanx.
Old Jul 14, 2003 | 10:09 AM
Default Re: (silverpenny)
i've got in now guys, i've got a tranny with a broken shift fork, so i'm just gonna take it out of the one that in it now and put it in the original si tranny. thanx for the help tho.
B-EVERYTHING
Jan 30, 2009 10:41 AM
aser1z
Apr 7, 2007 04:29 PM
91Notch5.0
Jan 6, 2005 02:11 PM
