vtec vs non vtec d-series
Old Jul 31, 2001 | 11:17 AM
sohc_boy's Avatar
Default vtec vs non vtec d-series
i want to build up a n/a d-series and was wondering which head would be better the non-vtec or the vtec. i know that there are more cams available for the non-vtec setup and i figure with some porting that it could make better power than the vtec head even with porting because i could get a much more aggressive cam for the non-vtec head than the vtec head. any thoughts?
Old Jul 31, 2001 | 01:02 PM
HXMan's Avatar
Default Re: vtec vs non vtec d-series (sohc_boy)
If anything the VTEC heads probably have better high rpm breathing capibility, and if you want power na....more rpms and more displacement are the only ways to go.
A non-vtec head will be simpler, but it may be less streetable if you get some crazy long duration, high lift, custom cams.
How fast do you want your car to be?
Old Jul 31, 2001 | 05:05 PM
clockworks's Avatar
Default Re: vtec vs non vtec d-series (HXMan)
Yeah, I'd say it's a toss up. Either a DOHC from an early D16 out of a 1st gen teg to have the tuning ability of two cams, or have it be a bit more streetable with the SOHC vtec. If you're getting crazy cams, possibly custom, for high rpm power, I'd take the non-vtec.
Greg
Old Jul 31, 2001 | 06:28 PM
Katman's Avatar
oooo..
I have a bunch of SOHC Vtec engine setup ideas...hit me up on email...I'll tell ya few...
I'm also making a webpage dedicated to engine build up suggestions for D & B series engines using mostly OEM parts. Someday I"ll finish it...
painful poop face
[Modified by Katman, 7:28 PM 7/31/2001]
Old Aug 1, 2001 | 09:20 AM
optiontoo's Avatar
New User
The non-VTEC heads have a combustion chamber design that is more detonation resistant than the VTEC heads. That means you can run more compression and more timing. (Of course, proper engine assembly is key.)
Old Aug 1, 2001 | 10:21 AM
sohc_boy's Avatar
Default Re: vtec vs non vtec d-series (optiontoo)
hmmm i thought the newer (96up) vtec heads had a better combustion chamber than the other d-series heads including the non-vtec? besides once i make a decision on the head vtec or not i will have it ported and i think whoever i send it too will mod the combustion chamber anyways.
Old Aug 1, 2001 | 04:14 PM
HXMan's Avatar
The 96 up do have better combustion chambers.....they are more round instead of square, that is what I heard.
Old Aug 2, 2001 | 04:05 PM
Red Civic T's Avatar
New User
KG says VTEC head will flow about 10% better, all else equal....
pleej
Mar 18, 2015 08:56 PM
charlieboyhonda
10
Oct 21, 2007 08:38 PM
civictildeath
Aug 2, 2006 08:22 PM
delsol31603
Jan 24, 2005 08:52 PM
cloproductions
Dec 29, 2002 01:57 AM
