Quick Question: Moly Lube on Cam Plate Bolts?
As the title says:
Do you use moly lube on cam plate bolts (like you use on ARP Head studs)?
And will "Engine Lube w/ Moly & Graphite" be fine? It is the only Moly Lube I could find. I don't have any ARP Moly Lube, and I was told any Moly Lube would would be close enough.
Thanks!
Thanks!
