Blue Smoke
Old Jul 12, 2003 | 09:55 AM
Civic4drR8cer's Avatar
Default Blue Smoke
WELL THIS MORNING I NOTICED BLUE SMOKE FROM MY MUFFLER... I POPED THE HOOD AND I NOTICED MY DISTRIBUTOR CAP WIRE FOR CYLINDER # 1 WAS OFF SO I PUT IT BACK ON
I THINK I MIGHT HAVE MESSED SOMETHING UP SOMEHOW BECAUSE THE BLUE SMOKE STILL GOES ON... ANY ANSWERS PLEASE HELP
Old Jul 12, 2003 | 10:01 AM
Malgerus's Avatar
Default Re: Blue Smoke (Civic4drR8cer)
First of all, stop typing in Caps. It's really freaking annoying!
Anyways, if your car was really running on 3 cylinders it would run like ****, and you would definitely have noticed before. Blue smoke denotes oil burning. Try doing a compression test. It could be a blown head gasket, bad piston rings, leaking valves, etc. Does it smoke at idle or under acceleration? Once you've done that and if it turns out to be ok, try doing a leakdown test (at a shop)... this will give you a more accurate diagnosis of your engine's internals.
EDIT: It could also be something as simple as a blocked PCV valve, which could cause oil burning.
Old Jul 13, 2003 | 11:17 AM
Default Re: Blue Smoke (Mr. S)
well i noticed it when i got my engine back.... i had to get a new engine because i blew my old one.. i didn't want to get a b-16 like everyone says so i got a 1991 crx si engine. but i realized that my distributor cap wire had fell off so i bought new ones and it works fine now .... thankx alot man
sde780
23
Feb 19, 2013 05:02 AM
EKk9
Jul 27, 2011 03:04 PM
KevinSmith88
Feb 23, 2009 04:20 PM
turboteg90
Sep 12, 2007 06:15 PM
4drGSR
Jun 19, 2001 05:15 AM
