Which Toda pump gear do I get?
It's a pain in the *** to pull my oil pump just to measure the gear and re-install it.. so I thought it would be easier just to order one and pull my **** apart just once.
Anyone measured a ITR oil pump gear? Is it 80mm or 84mm?
Thanks.
Thanks.
smaller gear gets the oil to the top of the motor faster. just a precaution at high rpms. needed? maybe not....but precautionary for people that run it up in the rpms
The stock oil pump gears are fine if you drag race, i.e. short bursts of high rpm use. But if your car is run in any kind of endurance race, i.e. 7~9000rpm constantly, then the stock oil pump gear will fail. The Japanse N1 cars all seem to use this TODA gear. The NSX guys have the same problem.
The stock gear and Toda gear are the same shape and grooves, The only difference is the metal, The Toda will last alot longer in High RPM Usage.
And yes its 84mm for the ITR.
