Best N/A Engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">I would have to say K-series.From what i remember in a post awhile back is that hytech has a 270whp K-series on pump gas.</TD></TR></TABLE>
I think its 270 at flywheel.
I take K over B. i wish i could swap a k in teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brainwo »</TD></TR><TR><TD CLASS="quote">
I take K over B. i wish i could swap a k in teg.</TD></TR></TABLE>
NO! its something like 320-310HP at the flywheel, and 270 to the GROUND!
10,000RPM redline also...
the K no doubt.
There is like at least 5 well known PRO Race teams coming out with their K Series all motor race motors pretty soon.
K20 w/ the big valve head, Toda A's, I/H/TP/E and a reflash gets you 240 to the wheels? I mean granted it was on a dynopack but still damn. That's so mild yet so powerful. You'd be pushing race only for those kinda numbers on a B-Series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kxkal »</TD></TR><TR><TD CLASS="quote">K-series or B-series?
K-series.
</TD></TR></TABLE>K-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6h8k »</TD></TR><TR><TD CLASS="quote">yeah K series is owning **** up..ugh i just hate the vavle cover
im feelin that!
"it should make about 270 - 280 to the wheels in mild street form"
320HP @ 10,000RPM (at the flywheel)
220 Lbs torq
86mm bore
86mm stroke
12:1 compression
custom carrillo rods
custom weisco pistons
endyn cylinder head
hytech roller cams
hytech valve springs
hytech Ti retainers
hytech intake & exhaust manifolds
hondata ECU program
</TD></TR></TABLE>im feelin that!
220 Lbs torq
86mm bore
86mm stroke
12:1 compression
endyn cylinder head
hytech roller cams
hytech Ti retainers
hondata ECU program
actually 320 fly 280 or so wheel @10krpm =-o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">how hard is a K series swap into an EK??does hasport make mounts???hows wiring, etc??anyone know where i can get a K series motor for nice n cheap?
Contact "Pacman" on the board (Marouj) he has a K20A motor in a EK...he can hook you up with mounts, wiring and the motor if you need it.
</TD></TR></TABLE>Contact "Pacman" on the board (Marouj) he has a K20A motor in a EK...he can hook you up with mounts, wiring and the motor if you need it.
wow thats crazy i just came to find this out i thought the k20's where junk,lmao guess i was dead wrong
how fast will the new si be with those #'s to the wheel 1/4 mile wise
TIA
-Ralf
how fast will the new si be with those #'s to the wheel 1/4 mile wiseTIA
-Ralf
will a k20 fit in a 94 teg? what internals are out for the k20?im in school now and will be working at an acura dealership this spring.i knew it was a good motor but i hope it will fit in my car.
dfoxengr
Oct 26, 2005 07:31 PM
