F/S:B16a1/Y1 complete swap. mounts, axles, ECU, shift linkage. Tacoma, WA
Old Jul 11, 2003 | 10:43 PM
NikoZai's Avatar
Default F/S:B16a1/Y1 complete swap. mounts, axles, ECU, shift linkage. Tacoma, WA
B16a1 engine with Y1 transmission. PR3 ECU.
Hasport mounts with extra bushings.
shortened shift linkage.
Passenger side axle is a Raxles B16CRX axle.
Drivers side is a 90 Integra Axle.
history: I did this swap the way it was supposed to be done. Then my car was jacked and my swap was transplanted into a pile of ****. Runs great though!
$2200 and that will include the header and exhuast if you move on it before my friends do
And nobody better tell me that's expensive. The cost from japan for an engine you need to replace everything on avg's $1500 without mounts. I'm cheaper and you get to drive the car that it's currently in if you come by this week! (we remove it 7/20)
PM me!
Old Jul 12, 2003 | 07:11 PM
NikoZai's Avatar
Default Re: F/S:B16a1/Y1 complete swap. mounts, axles, ECU, shift linkage. Tacoma, WA (NikoZai)
bump
240sxDrift
Aug 3, 2005 07:55 AM
SpiritUnreal
May 1, 2003 09:54 PM
TypeR0207
Aug 9, 2001 02:22 PM
