what fuel pressure
Old Jul 11, 2003 | 09:44 PM
wanttorace's Avatar
Default what fuel pressure
im running a b20b with a gsr head and its got a stock fuel pressure regulator and its running really rich im wondering since is has a low compression do i have to turn it down what are some numbers you guys are running?
Old Jul 11, 2003 | 10:42 PM
irev210's Avatar
Default Re: what fuel pressure (jjd493925)
are u sure your running rich, and are you sure there is no problem with your map sensor or something
Old Jul 11, 2003 | 11:49 PM
jdmcx's Avatar
Default Re: what fuel pressure (irev210)
its a new map sensor on there we put a new one on because the old one broke
Old Jul 11, 2003 | 11:56 PM
irev210's Avatar
Default Re: what fuel pressure (jdmcx)
as long ast he map is hooked up correctly, it shouldnt be running rich, what codes do you have.
Old Jul 12, 2003 | 10:53 AM
wanttorace's Avatar
its throwing a coolant temp code and thats it and the exhuast is real black running real rich
Old Jul 12, 2003 | 11:55 AM
non-VTEC's Avatar
try replacing the coolant temp sensor. if the sensor is bad and it's making the ECU think the engine coolant temp is still cold it will cause it to run very rich.
that might help a bit
Old Jul 13, 2003 | 09:08 PM
wanttorace's Avatar
Default Re: what fuel pressure (non-VTEC)
what would that have to do with the fuel im not trying to be an *** could you explain it to me
JDM_EK4_Coupe
Apr 24, 2007 08:19 PM
JDM_EK4_Coupe
Apr 24, 2007 07:08 PM
wiZCo
Sep 8, 2006 01:03 PM
burgerbuddy
11
Aug 7, 2005 05:54 PM
quicksol95
Feb 25, 2005 09:22 AM
