help will not start all the time (wtf)
Old Jul 11, 2003 | 08:42 PM
tdc's Avatar
tdc
Default help will not start all the time (wtf)
my car a 92 gsr and sometimes when i get in it ..it will start then die right away..then if i try to start it again ..it won`t start.. it takes 3 to 4 trys or if i let it sit for 2 or 3 min then it starts up ..what the hell is going on here ...btw i just put new plugs wires and dis cap and still does it help
Old Jul 11, 2003 | 09:00 PM
Calavera's Avatar
Default Re: help will not start all the time (tdc)
Check your map sensor. could be also your ignition switch. check that you have spark in each cylinder.
Old Jul 11, 2003 | 10:19 PM
tdc's Avatar
tdc
Default Re: help will not start all the time (Calavera)
how do i check map sensor..and it doesn`t do it all the time so buy the time i get out and check 2 plugs for spark it`ll start..also i checked for any codes and when i put the jumper in the eng light stays on but no flashing is this right??i don`t get it why would it not start for 3 or 4 trys then let it sit for a few minites and it fires right up..come on somebodys gotta give me a clue
Old Jul 12, 2003 | 05:54 AM
DCStreetHtch's Avatar
<-- got the same problem
is it bogging out or just cutting out smoothly???
i'd like to save my money on buying new cap, rotor and plugs if we have the same symptoms??
-Bryan-
Old Jul 12, 2003 | 07:28 AM
tdc's Avatar
tdc
Default Re: help will not start all the time (EGStreetHtch)
no bogging at all ..just fires and dies right away then it only cranks over let it sit for a few and fire right up.. run fine after it starts but every 3rd or 4 day it goes though this won`t start crap the cap and wire stuff made it run better but didn`t fix the starting at all
Old Jul 12, 2003 | 07:45 AM
i got nothing then... mine likes to bog out, with no repsonse from the throttle... i think my resistorless plugs are fouling out... good luck
-Bryan-
Old Jul 16, 2003 | 08:28 PM
Spoonin's Avatar
Got the exact same problem with my 90 teg. Does anybody think it might be the main fuel relay? Maybe the ignitor? I played around with my main fuel relay last night and it starts and then, after it warms up I will turn it off and it won't start again.
Old Jul 16, 2003 | 10:09 PM
startroops's Avatar
Default Re: help will not start all the time (Spoonin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonin &raquo;</TD></TR><TR><TD CLASS="quote">Got the exact same problem with my 90 teg. Does anybody think it might be the main fuel relay? Maybe the ignitor? I played around with my main fuel relay last night and it starts and then, after it warms up I will turn it off and it won't start again.</TD></TR></TABLE>
80% of the time, this is a MFR's problem. Get it changed and the problem should go away. Good luck.
Old Jul 17, 2003 | 07:47 PM
Spoonin's Avatar
Default Re: help will not start all the time (startroops)
http://www.markl.f9.co.uk/howt...y.htm
Yup! It was the MFR! Check out the above site (just the first part, don't try to fix the relay, it won't be worth your time). I had the exact same problems with my car. It would not start when it was hot, play with the key for a little while or let it sit and it would start. Sometimes after a short run (like getting gas) the car won't start after it has been turned off. Started and died on me after a few seconds like, 5 times in a row. Got a new relay today and I haven't had a problem starting the car now.
Old Jul 17, 2003 | 08:44 PM
bad link my friend.... bump
-Bryan-
Old Jul 19, 2003 | 12:44 AM
Spoonin's Avatar
sorry bout that
tambara
16
Apr 20, 2008 01:01 PM
spacin
Dec 27, 2007 11:21 AM
tasco
Aug 18, 2006 12:18 PM
93h22a1vtec
Jun 3, 2006 07:47 AM
.one lane
Oct 17, 2005 07:40 PM
