problem with h22(posted in prelude forum too)
Old Jul 11, 2003 | 08:29 PM
b18bEG's Avatar
Default problem with h22(posted in prelude forum too)
OK so i was driving today, and i needed to switch lanes before someone hit me.... i noticed that i had much less power than normal.... so i justa waited untill 4600 rpm for vtec to kick, right when vtec kicked in i lost ALL power, and it was like the rev limiter turned on.. i have NO CEL, oil is good.... oh yah and there is some ticking in the motor when you listen to it.. someone please help me!! thx in advance
Old Jul 11, 2003 | 11:03 PM
94cd7's Avatar
Default Re: problem with h22(posted in prelude forum too) (h22akrd)
sounds like you may have bent your valves in your motor have you over revved it lately
Old Jul 12, 2003 | 12:18 PM
b18bEG's Avatar
no over revving, i was thinking valves too
Old Jul 12, 2003 | 01:39 PM
GZERO's Avatar
Can u do a compression test? it might sound like a dist problem
Old Jul 12, 2003 | 04:21 PM
b18bEG's Avatar
just got back from changing out vtec cylaniods(sp?!), adn checking most of the wiring. so no verdict, gunna try the ecu tomorrow
Old Jul 13, 2003 | 01:09 PM
poison's Avatar
Default Re: (h22akrd)
ahh that blows man.
do a compression test and let us konw the results.
also pull your sprk plugs and see waht the deal is.
Old Jul 13, 2003 | 10:47 PM
MAX HARDCORE's Avatar
Default Re: (poison)
dont flip out yet, check your vacum lines may be your wiring is not attached strongly
it dosent sound like a valve problem.
Old Jul 13, 2003 | 10:48 PM
Default Re: (MAX HARDCORE)
BTW did you get that FMU i sent you?
Old Jul 15, 2003 | 07:14 AM
b18bEG's Avatar
are you talkingto me about the FMU, i thought your name was filthy frank?
Old Jul 15, 2003 | 09:45 PM
it was i forgot my password, now here i am
Old Jul 16, 2003 | 07:34 AM
b18bEG's Avatar
yes i did get get it then, thanks man looks great, soory to day that im not gunna be able to use it, but its a good peice top have for later
thecorey
Sep 26, 2009 04:58 PM
John M
Jun 7, 2008 07:54 PM
98Preluder7
Oct 26, 2004 09:40 PM
b18bEG
Jul 14, 2003 07:25 AM
DocV
Jan 10, 2003 06:58 PM
