2inch intercooler piping will it flow 300whp? D-series engine
Old Jul 11, 2003 | 05:48 PM
Drew Peacock's Avatar
Default 2inch intercooler piping will it flow 300whp? D-series engine
I already have some nice 2 inch piping made up with my existing setup but am unsure if it will flow 300whp. I remember being told by a tuner that 300HP was about the limit for 2 inch piping. Does anyone have real world knowledge on this?
Old Jul 11, 2003 | 06:28 PM
CzanSOHC's Avatar
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (turbozxi)
2" is good.
Old Jul 11, 2003 | 06:35 PM
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (CzanSOHC)
Your sure? What are the limits of 2inch piping do you know?
Thanks for the reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CzanSOHC &raquo;</TD></TR><TR><TD CLASS="quote">2" is good.</TD></TR></TABLE>
Old Jul 11, 2003 | 06:41 PM
ion_four's Avatar
I did the calculation when I was buying my piping and it tops out right around 300hp. I would say to go with it before the intercooler, but at some point before the intake manifold switch up to 2.5" so it's not a DRASTIC transition to the throttlebody...
Old Jul 11, 2003 | 06:50 PM
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (ion_four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">I did the calculation when I was buying my piping and it tops out right around 300hp. I would say to go with it before the intercooler, but at some point before the intake manifold switch up to 2.5" so it's not a DRASTIC transition to the throttlebody...</TD></TR></TABLE> Do you mean 300 wheel HP or Flywheel?
So your saying I could use the 2in piping I have before the intercooler and untill once its straightens up after the intercooler, then
weld on some 2.5in piping. That maybe reasonably easy to do.
Old Jul 11, 2003 | 07:14 PM
romeo619romeo's Avatar
actually just use 2 1/2 rite after the intercooler, reason of using 2 inch b4 the intercooler.. is to speed up the compressed air
Old Jul 11, 2003 | 08:04 PM
TurboTegB18c's Avatar
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (romeo619romeo)
2"inlet/2.25 outlet, 2.5 into throttle body here, check sig for power.
Old Jul 11, 2003 | 08:18 PM
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (TurboTegB18c)
The bend on the out let of the intercooler will be tricky to remanufacture the intercooler itself has only 1 3/4in openings anyways. So it will be easiest to add the 2.5inch piping once its straightened out.. This should work shouldn't it?
I still would like a conclusive answer as to whether or not I HAVE to change my original 2in piping!!! To make 300whp .
Old Jul 11, 2003 | 08:37 PM
I'm not positive but i think the 2inch piping will hold up to 300whp. Just my opinion, no facts.
Old Jul 11, 2003 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">I'm not positive but i think the 2inch piping will hold up to 300whp. Just my opinion, no facts. </TD></TR></TABLE> Anyone else know?
Old Jul 12, 2003 | 12:02 AM
*Boostwerks*'s Avatar
2" is fine...
Old Jul 12, 2003 | 08:06 AM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">actually just use 2 1/2 rite after the intercooler, reason of using 2 inch b4 the intercooler.. is to speed up the compressed air</TD></TR></TABLE>
Why the **** would you want to speed up the compressed air?
Do you run a half-inch exhaust too, to speed up the exhaust gasses?
Old Jul 12, 2003 | 08:15 AM
lazerus's Avatar
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (kpt4321)
damn dude chill.
use the same size piping as the intercooler is equipped with, or slightly larger. (2" is just fine)
Old Jul 12, 2003 | 12:33 PM
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (lazerus)
Thanks guys so 2inch should be fine. I think I will try and see anyone think the 1,3/4inch intercooler inlet and outlets are going to cause problems? The intercooler is off a Mitsibishi Galant Vr4 I think starion inetrcoolers are similar??
Old Jul 12, 2003 | 02:13 PM
kpt4321's Avatar
Don't use the GVR-4 intercoolers, they are not good at all.
The Starion IC's are also not too great, but they are better than the GVR-4 ones.
Get a muffler shop or a welding shop to cut the inlet and outlet off, and give them some bigger pipe to weld on.
Old Jul 12, 2003 | 02:39 PM
Default Re: (kpt4321)
Maybe we talking about different intercoolers, the one I am talking about is pretty good, looks much like the intercoolers people get with there kits. I mean it works fine for the 200whp I am making at the moment!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">Don't use the GVR-4 intercoolers, they are not good at all.
Old Jul 12, 2003 | 03:18 PM
MachAF's Avatar
There's this thing called turbo lag, have you heard of it.
Old Jul 12, 2003 | 03:43 PM
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (MachAF)
This is a Vr4 intercooler I am pretty sure except it has bigger inlet/outlets welded on stock they have 1 3/4in. I am wondering if this will flow 300whp with the original 1 3/4in inlet/outlets Pic stolen from http://www.thezcresource.com I hope Bryson doesn't mind..
Old Jul 12, 2003 | 04:03 PM
BoostedED9's Avatar
that is a starion intercooler..
i ran 2.5" piping for all my intercooler pipes on my car....
Old Jul 12, 2003 | 04:07 PM
Tomek's Avatar
Default Re: 2inch intercooler piping will it flow 300whp? D-series engine (BoostedED9)
This is a gvr4 intercooler.......
its a POS.
Old Jul 12, 2003 | 04:14 PM
drumking15's Avatar
kpt4321 knows his ****...any recomendations he suggests id take them
Old Jul 12, 2003 | 08:48 PM
Default Re: (drumking15)
Thanks for the reply's I think the starion intercooler should work well enough but I am a little worried about the 1 3/4in inlet/outlets. I am broke as hell and don't want to change them if I don't have to, but I do want 300whp . What do you think will the stock starion intercooler flow that much.
Old Jul 12, 2003 | 10:06 PM
you must be a big idiot....not every1 runs a massive turbo that can fill up the piping b4 the intercooler....so b4 you talk , ask some1 properly why they would do that.. its a basic phyisics law.. you try to blow into a 2 inch piping and feel the other end of it you have no air pressure.. compared to you blowing into a straw and see whats the difference in air velocity...now whos the stupid ****
Old Jul 12, 2003 | 10:10 PM
what a joke this is a joke rite... id hope so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">kpt4321 knows his ****...any recomendations he suggests id take them</TD></TR></TABLE>
Old Jul 12, 2003 | 10:34 PM
Default Re: (romeo619romeo)
Come on dude you are not helping me get an answer to my question. If you can't help don't post.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">what a joke this is a joke rite... id hope so
