car wont start
Old Jul 11, 2003 | 01:37 PM
HatchBox's Avatar
Skoobie no more...
Default car wont start
ok guys i need your help my bro has a 90 civic 4dr...well the car was working fine but one day it just quit. When you go to start it doesnt turn over.. it sounds like its just gonna turn over but it doenst..now on the positive terminal of the batter there is 2 fuses...and there is 2 wires that run into it a white with green stripe and i forget what color the other one is..well anyways were that plugs into that little fuse box it looks really shitty and corroded. and it donesnt look good...i followed them and they run right into the main harness...could this be my problem? or i was also thinking that it was maybe the altenator...suggestions? thank you
* we have also tried to jump it but it wont start
*Battery is good
Old Jul 11, 2003 | 01:49 PM
crxchris's Avatar
do u have a spark? do your lights turn on ? and chek fuses to see if any are blown also is there any codes being thrown
Old Jul 11, 2003 | 02:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (crxchris)
how do i check for spark...i havetn been able to go out and check code yet its been raining
EDIT - car istn throwing any codes
Old Jul 11, 2003 | 03:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (ind3ciso)
anyone?
Old Jul 11, 2003 | 06:13 PM
Lo-Buck EF's Avatar
two stupid ef tricks.
1. open gas cap to vent tank. vaperlock sucks.
2. disconnect fuel injector plugs, then re-plug in. they loose there ground.
if not, check for spark, fuel, ect...
Old Jul 11, 2003 | 06:22 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">1. open gas cap to vent tank. vaperlock sucks.</TD></TR></TABLE>
BINGO...thank you!!!
Old Jul 12, 2003 | 12:56 AM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">
BINGO...thank you!!!</TD></TR></TABLE>
Man if that actually worked!!! HAHAHA!!! nice work man
Old Jul 12, 2003 | 03:18 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (Smokinsax)
haha yeah i ran out side popped the gas tank....and PSSSSSSSSSH and then i went and started it ...and she turned right over... i would have never guessed that to be the problem
ant13
May 19, 2011 08:39 AM
dbailey
18
Jan 4, 2007 01:35 PM
egcivic
Nov 20, 2006 05:32 PM
jshi182
Jun 20, 2006 09:16 PM
markchans
Dec 21, 2005 11:43 AM
