Eibach Pro-Kit/Koni Yellow Install: Bumpstops?
I bought a used set of yellows/prokit..
no instructions.
How much do i shave off the bumpstop and where/how? Anything else I need to know from the instructions that are missing?
Thanks,
Rubens
no instructions.
Thanks,
Rubens
Check out all three of these sites and extract infromation that you can use from all of them since they all vary in technique. Here's a real good tip, before you attempt to remove the bolts on rear LCA soak the bolts overnight FIRST with some liquid wrench teflon, pb blaster or something like that, matter of fact, soak all bolts you'll need to remove, It'll save some potential snapped bolts. Maybe have a breaker bar on hand too.
http://jdmfan.com/technical/su...ings/
http://www.bseries.net/html/garage/spring.php
http://internet.cybermesa.com/....html
make it good, but more important, make it right
you are missing the prokit instructions, it should tell you. If I remember correct it is ~25mm. 30mm is close enough, I'd just cut in the 1" area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rubens »</TD></TR><TR><TD CLASS="quote">Are you sure? I've heard 30 mm
What info am I missing from the prokit/yellows instructions??</TD></TR></TABLE>
On my tokico illumina \ skunk2 coilover install I cut them in half. Right where it goes from fat to skinnier and I have no problems. Good luck.
Mike D
13
Sep 17, 2002 06:49 PM
ILUVTEC
Apr 15, 2002 11:41 AM
