Mantinence lights flashes
Old Jul 11, 2003 | 11:00 AM
Xumarius's Avatar
Default Mantinence lights flashes
Hey people I have a questions for you because I dont know whether I should worry...
When I start my car the mantinence lights flashes several times and then goes off. I know that It isn't because I just stared the car because It all of a sudden started doing this recently. I have a clifford alarm on my car. I'm not really sure that that is the problem.
Any thoughts...
Old Jul 11, 2003 | 11:02 AM
babes 99 GSR's Avatar
Default Re: Mantinence lights flashes (Xumarius)
It's probably supposed to go into acura for maintenance. You can turn the light off yourself and do the maintenance yourself too.
Old Jul 11, 2003 | 11:03 AM
Default Re: Mantinence lights flashes (99GSR1980)
Also, the manual says what all the lights mean and whatnot...
Old Jul 11, 2003 | 11:07 AM
timmy8151's Avatar
The maintenance light is just an idiot light. The light doesn't know if there is a problem and I believe is set to go off every 7500 miles.
Old Jul 11, 2003 | 11:10 AM
skunkintegra's Avatar
Default Re: Mantinence lights flashes (timmy8151)
look under ur steering wheel for a button, this will get rid of the light!!
Old Jul 11, 2003 | 11:31 AM
JeremyL's Avatar
Default Re: Mantinence lights flashes (skunkintegra)
under the steering column and to the right there is a little box with a blue button on it, hold in that button and start the car and keep holding it until it goes away
Old Jul 11, 2003 | 12:07 PM
THE94GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xumarius &raquo;</TD></TR><TR><TD CLASS="quote">Hey people I have a questions for you because I dont know whether I should worry...
Any thoughts...</TD></TR></TABLE>
i belive there is nothing wrong with ur matinence light if u look at ur abs light when turning on ur car it will do the same it will flash a couple of times and turn off.. if your car would need mantience then the light would stay on then u would have to go ahead and reset it... sounds normal to me..
Old Jul 11, 2003 | 03:27 PM
Cramerox's Avatar
Default Re: Mantinence lights flashes (JeremyL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">under the steering column and to the right there is a little box with a blue button on it, hold in that button and start the car and keep holding it until it goes away</TD></TR></TABLE>
you dont need to start the car..switch the key to second postion and hold the button down untill the light stops. since its flashing you probably have to turn the key of and on again to see if the light stop flashing.
Perkul8r
Acura TL, RL & ZDX
Sep 22, 2009 06:36 PM
dajman94
Jan 15, 2007 01:52 PM
JLSIII
Acura TL, RL & ZDX
Nov 11, 2003 12:07 PM
