JDM Conversion HID question- a new one!
Does anyone know how or where all these brackets install? To be honest I am having this professionally installed, but when I first did the JDM conversion (non HID) the body shop asked me how to do everything but wipe their asses. I received a ton of brackets with my HID setup and am curious where all this metal will fit...!? I know that the AC lines need to be bent a bit to allow the boxes to fit so I'll mention that.
Also, anyone used an actual different bulb than the phillips one provided with the OEM housings? Other D2S bulbs?
You might want to bend the ac lines yourself. You have to be delicate so that you don't snap them or obstruct flow. Most body shops mangle the lines. They only need to be bent slightly in order to clear.
And as for the metal brackets, do you have pics of them?
ask integobsession and pdcdragon on here, they did the install themselves... also, Canuck-MX6 might be able to help you out. What year is your car?
ITR 2K
May 1, 2002 04:59 PM
