ZC into 91HF swap questions
Old Jul 11, 2003 | 06:54 AM
Ninja91HF's Avatar
Default ZC into 91HF swap questions
I am getting a ZC put into my 91 HF and I was wondering if anyone can answer these questions.
Can I use my stock tranny
Can I use an ECU from a 1989 Integra
What is the model of the ACT clutch kit for the stock tranny
Thanks in advance
Old Jul 11, 2003 | 07:35 AM
slooogsr's Avatar
dude i really wouldnt use the stock tranny unless you are in a bind. The teg ecu will work but the zc ecu is best. I have a zc ecu for sale if u want it let me know. As far as the clutch goes, its a 21 spline trans if its a 91......... when u call to order one just ask for an application for a 90-91 rex. everything cept the grearing is different between the two. good luck
Old Jul 11, 2003 | 07:59 AM
Ninja91HF's Avatar
Default Re: (sloorex)
will the stock tranny hold up? I am also planning on eventually running around 6psi boost. how much for the ecu?
Old Jul 11, 2003 | 08:02 AM
AudioXtremes's Avatar
Default Re: (Ninja91HF)
you REALLY don't want to use that tranny. Save you some work and heartache and save for an si or zc tranny.
Old Jul 11, 2003 | 08:36 AM
jdwebmaster's Avatar
yeah dont keep the HF tranny the car wil have power but the gearing will not let u use it.
Old Jul 11, 2003 | 09:04 AM
Ninja91HF's Avatar
Default Re: (jdwebmaster)
What else would I need to make it work with a ZC tranny - Axles? hubs? etc...?
Old Jul 11, 2003 | 09:40 AM
slooogsr's Avatar
i believe you would need teg axles and hubs for that to work. and if you want the ecu its yours for 50...... let me know i can take some pics if you need them......
Old Jul 11, 2003 | 09:41 AM
slooogsr's Avatar
ohhh and with the hf you can retain the stock axles and hubs if you find an si trans from a 90-91........ this way you wont have to change out the axles and hubs for the zc............ i am using an si trans.
Old Jul 11, 2003 | 09:46 AM
Ninja91HF's Avatar
$50 sounds good. Do you have paypal? How soon can you ship it out? The ZC gets in on Monday.
Old Jul 11, 2003 | 09:48 AM
Ninja91HF's Avatar
Do I need a sub-harness or can I use the stock wiring harness
Old Jul 11, 2003 | 10:42 AM
HF2ZC's Avatar
You can modify the stock harness to use the ZC distributor plug or make your own sub - harness. I made my own sub - harness by cutting the plug off of an HF or Si distributor and cutting the distributor plugs off of an 88 - 89 Integra harness. Connect the wires and you have a wiring harness for the ZC conversion. Check out this page (not mine) to see how the harness is wired up: http://dmoore.com/crx/zc-phase3.htm
Old Jul 11, 2003 | 06:28 PM
slooogsr's Avatar
i can ship it out on monday....... yea i have paypal........ just lemme know ur address and i will get a total........ shouldnt cost much to ship it.......... also give me ur email address so i can send u a pic so u feel better about it.......
Gen4Si
Feb 21, 2005 03:34 AM
ivanson
16
Feb 6, 2005 08:00 PM
C-REX 88
Jan 19, 2005 08:06 AM
JackAcc
Jul 13, 2003 01:24 PM
honduh-guy
Feb 26, 2002 09:19 AM
