Alum. or steel BOV mount flange?
The greddy kit doesn't already have a flange mounted on it? You have to find out what the piping is. I think greddy uses aluminum but I am not sure. What ever the pipe is you need that material for the flange.
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
what is th ematerial of your charge pipe to your throttle body? If it's steel, then get a steel one. If it's aluminum, then get aluminum..
I reused my old AEM cold air intake, which are aluminum and just had a dude weld on a aluminum flange on it.
