REFEREE TICKET
Old Jul 10, 2003 | 10:20 PM
c8r9x's Avatar
Default REFEREE TICKET
alright guys my friend is REALLY shi**ing it cuz he got a referee ticket and its coming up and he doesnt know what to do...he's running H22 in a eg hatch and they told him he has to see a state referee....if anyone knows how the ticket works or what he gets signed or better yet if anyone knows how to make it "go away" with some cash we would both greatly appreciate it....thx
Old Jul 10, 2003 | 10:40 PM
MG's Avatar
MG
Default Re: REFEREE TICKET (c8r9x)
If the engine is newer than the car, then you can make it legal as long as all the stock parts are there. If it's not, your friend has a problem.
Old Jul 11, 2003 | 06:56 AM
wuhungsixxx's Avatar
New User
Ref tickets will not just "go away"...they are State run smog shops...thats why cops write these tickets out when they see swaps...
your motor can be legal...and going to a smog ref in CA is the only way of making the swap entirely LEGAL...
search for BAR STICKER or SMOG REF in the archives in all forums...you will find info that will help you
call 1-800-622-7733 to make an appointment with a ref near you
Old Jul 11, 2003 | 07:14 AM
andrew dc's Avatar
Default Re: REFEREE TICKET (wuhungsixxx)
HAHAHA... You live in alhambra.. I used to live there and the cops are asses!!! go to the state ref to get the motor legal in your friends car. may of us here that live in CA get the swap legals so we are not harassed buy the cops...
Old Jul 11, 2003 | 07:45 AM
ATS_Antone's Avatar
Default Re: REFEREE TICKET (andrew ef)
what i did when i got a ref ticket...
I went to the police station after 530pm or so ...so most of the in office cops were at home by that time. I went in to get the ticket signed off ....the guy actually signed off on it. I then went to court to talk to the judge and showed him that its signed off. The judge then dismissed it. Maybe i was lucky or maybe it will work everytime. Its definitly worth a shot because a ref ticket is no joke...especially in cali w/ a jdm motor.
Old Jul 11, 2003 | 07:58 AM
EF_LSVtec's Avatar
Default Re: REFEREE TICKET (antone)
Getting your car to pass now is even harder than before. All smog and referee stations have to run your car on a dyno-type machine now. So your car will have a load and actually rolling when it is being tested. Good luck.
Old Jul 11, 2003 | 08:39 AM
andrew dc's Avatar
Default Re: REFEREE TICKET (EF_LSVtec)
not unless they changed that this month.... I went last month and it was the same sniffer test.. no rollers, not until jan 1st
Old Jul 11, 2003 | 08:54 AM
EL Vap133's Avatar
Take a friends stock hatch and do a number job....
Old Jul 11, 2003 | 09:17 AM
ThatRicerDaniel's Avatar
Default Re: REFEREE TICKET (Vap133)
so the dyno test will only be a at state ref locations correct?
Old Jul 11, 2003 | 09:31 AM
andrew dc's Avatar
Default Re: REFEREE TICKET (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">so the dyno test will only be a at state ref locations correct?</TD></TR></TABLE>
come next year.... rollers everywhere... all smog places have to get re-licensed and install expensive rollers
Old Jul 11, 2003 | 07:21 PM
c8r9x's Avatar
well on a side note, the roller thing is going to suck, but back 2 the referee ticket...the motor is i believe a 94 and the car is 92si...the car is stock except for fuel pressure regulator, intake, msd ignition, hot shot header, and magnaflow muffler...the muffler is quiet though and "50 state legal"
Old Jul 11, 2003 | 07:24 PM
c8r9x's Avatar
also other than putting everything back to stock how can we make the car street legal?
Old Jul 11, 2003 | 08:38 PM
EF_LSVtec's Avatar
94 motor...your car should be wired obd-1 with stock intake and tube, stock exhaust and catalytic. btw, new law on dyno type machine is effective now (July) and not just the referree station but all smog stations.
Old Jul 11, 2003 | 08:50 PM
ninjaMONKEY
Guest
Posts: n/a
as long as the motor is newer then the car which it seems to be and the obd is the same as the motor/car or newer its legal as long as it passes smog. You also need to be running a prelude ECU and make sure all the smog equippment is hooked up. I hear the EGR valve/sensor is a pain in the *** to wire. Good luck
Old Jul 11, 2003 | 10:17 PM
c8r9x's Avatar
Default Re: REFEREE TICKET (ninjaMONKEY)
the ecu isnt the p13 he has a stock computer programed by prospeed....so as long as the car passes smog it should be legal? i guess that makes sense from there point of view
Old Jul 12, 2003 | 12:58 AM
ninjaMONKEY
Guest
Posts: n/a
the ref needs to see it and hes the one smogging it he might overlook the computer but technically he needs to have a prelude computer p13 i believe are the prelude ECU's
Old Jul 12, 2003 | 01:47 AM
91_hatch_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">so the dyno test will only be a at state ref locations correct?</TD></TR></TABLE> how is it harder when you still only have to rev the car to 2500 rpm?
Old Jul 12, 2003 | 05:11 AM
91civicDXdude's Avatar
Default Re: REFEREE TICKET (91_hatch_si)
i guess thats one good thing about living in the hick *** midwest. no smog testing
Old Jul 12, 2003 | 06:30 AM
y49crxsi's Avatar
Default Re: REFEREE TICKET (91civicDXdude)
GO FLORIDA!
Old Jul 13, 2003 | 11:51 PM
c8r9x's Avatar
Default Re: REFEREE TICKET (y49crxsi)
so you guys are sure that if everything is stock that it will pass ref?...and antone when you got it signed off who did you see and did they put a sticker on the back of the ticket saying you had to see the state ref?
Old Jul 14, 2003 | 05:48 AM
Gir's Avatar
Gir
How did the officer know your friend had a swap ?
even if they looked under the hood I cant imagine them spotting it.
Old Jul 14, 2003 | 07:35 AM
andrew dc's Avatar
Default Re: REFEREE TICKET (Gir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gir &raquo;</TD></TR><TR><TD CLASS="quote">How did the officer know your friend had a swap ?
even if they looked under the hood I cant imagine them spotting it.</TD></TR></TABLE>
alhambra or the san gabriel valley cops are trained in import mods/swaps.. there is supposedly a special task force that is specificaly trained in spotting illegal modifications.
As for knowing if you went to the ref.... you get a sticker saying you are carb legal.. or you don't... if you get the sticker, you are good to go.. if you don't... you better do you home work and get it all set up...
read up here: http://honda.hybrids.jp/forum/...&vc=1
Old Jul 14, 2003 | 08:21 AM
CLICC916's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew ef &raquo;</TD></TR><TR><TD CLASS="quote">
come next year.... rollers everywhere... all smog places have to get re-licensed and install expensive rollers</TD></TR></TABLE>
just went to ref about 2 weeks ago...my car was put on the rollers...didn't pass of course, but the ref was cool about it and told me to go obd1 del sol b16a
Old Jul 14, 2003 | 08:26 AM
Gir's Avatar
Gir
in general (not CA) is it hard for the japanese b16's to pass a normal smog test ?
Old Jul 14, 2003 | 09:04 AM
MG's Avatar
MG
Default Re: (Gir)
It's easy to pass smog, it's the visual check that is hard.
