88 hf w/ZC no spark = no start?
Old Jul 10, 2003 | 08:44 PM
xsellxoutx's Avatar
Default 88 hf w/ZC no spark = no start?
after swap car wouldn't start i got fuel, but no spark.
i changer the coil and the motor already had a new cap, rotor, plugs, and wires.
any ideas? maybe the ignitor? motor was running perfect b4 it can out of my friends 91 si.
thanks,
-chris
Old Jul 10, 2003 | 09:23 PM
91civicEX's Avatar
did you do any distributor rewiring? that could be a problem.
Old Jul 10, 2003 | 09:36 PM
xsellxoutx's Avatar
Default Re: (91civicLX)
i didn't change the harness it came to me wired w/ a si harness already so wiring is correct.
Old Jul 10, 2003 | 11:14 PM
JCracer723's Avatar
Default Re: (xsellxoutx)
check ur grounds
Old Jul 10, 2003 | 11:15 PM
blah13's Avatar
So long as your wiring is 100% correct the ignitor is your best bet. Or swap a known good dizzy for the one that came with the ZC, I've heard bad things about ZC dizzys *knock on wood*
Old Jul 10, 2003 | 11:19 PM
my91civic's Avatar
Default Re: (JCracer723)
[Q
UOTE=JCracer723]check ur grounds [/QUOTE]
Old Jul 11, 2003 | 01:28 AM
xsellxoutx's Avatar
Default Re: (my91civic)
what grounds? in the dizzy? or what i've got extra grounds on the motor.
Old Jul 11, 2003 | 02:30 AM
paulzy's Avatar
had something similar...running SI motor was thrown in HF, no spark...didn't find out what it was, motor is now out of teh car
Old Jul 11, 2003 | 05:55 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx &raquo;</TD></TR><TR><TD CLASS="quote">i didn't change the harness it came to me wired w/ a si harness already so wiring is correct.</TD></TR></TABLE>
yea- even if the wiring was off you'd still get spark (I know from experience lol ) check the ignitor
Old Jul 11, 2003 | 10:00 AM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx &raquo;</TD></TR><TR><TD CLASS="quote">what grounds? in the dizzy? or what i've got extra grounds on the motor. </TD></TR></TABLE>
yes there are grounds on the car. valve cover. the wirin harness has grounds. the starter has a ground.. check them all
Old Jul 11, 2003 | 10:33 AM
therealciviczc's Avatar
What ECU?
Did you check the ECU fuse and hazzard fuse?
Is the car cranking over?
If the HF motor ran and the ZC is wired correctly, it should be no problem. I'd check fuses related to the ECU. I'd make sure no wires got pulled out of a plug or torn during the swap (it happens some times especially on plugs that people repinned where you can't really tell the wire is out). I'd triple check all of the grounds, connections, plugs, sensors, etc.
You know you're getting fuel, right?
It would be unusual for an ignitor to just go bad during a swap, but not impossible.
Old Jul 11, 2003 | 11:07 AM
MixdCrix's Avatar
My buddy had the same prob a couple of weeks ago...dizzy-prob igniter-try a known working distrib on it...I used mine on his car and it fired right up.
Old Jul 11, 2003 | 11:13 AM
yourfacesucks's Avatar
Default Re: (MixdCrix)
whats it doing chris is it turning but not starting if so i bet that it is the ignitor mine just went out the other day it was instantaneous i was driving and bam nothing it really sucked because i was on a delivery.........if its not doing **** when you turn it on then check the grounds you have valve cover ground tranny ground and a ground that comes out of the harness that bolts to your thermostat housing make sure you got that one on or nothing will start............you see thats what you get for not letting me be there during your swap damn amatuers.........no really call me and ill see if i can figure it out i gots yo back fool............
Old Jul 11, 2003 | 11:32 AM
SecretAgent's Avatar
also make sure the harness ground is connected on the thermostat housing. that's the ignition system ground.
Old Jul 11, 2003 | 12:20 PM
Default Re: (SecretAgent)
yes i already said that make sure you check that one chris its very important and you see i do know what im talking about...........
Old Jul 12, 2003 | 08:09 PM
xsellxoutx's Avatar
Default Re: 88 hf w/ZC no spark = no start? (xsellxoutx)
ok i double checked the grounds and replaced the ignitor and still no start?
Old Jul 12, 2003 | 11:46 PM
h22 ef's Avatar
hf motors use 2 injectors dont they? and your using a si wiring harness, i dont know if the hf's are like the dx but even with the si harness you still have to convert the ecu harness to si
Shaw14
Jul 24, 2010 05:15 AM
pyro_freak8
Mar 25, 2004 01:30 PM
pyro_freak8
10
Mar 24, 2004 12:10 PM
messeduprex
Apr 6, 2003 10:24 AM
