Honda glue
Old Jul 10, 2003 | 07:22 PM
michael O's Avatar
Default Honda glue
I posted this already in the tech section and apparently no1 has ever stripped down an engine that's been apparently glued together. I'm currently stripping down my engine and the last person glued the engine together. Does anyone know how to remove this glue from all the parts of the engine.
Old Jul 10, 2003 | 07:24 PM
the DR.'s Avatar
Default Re: Honda glue (michaelOlson)
um.. what kind of glue are you talking about? never heard of anyone glueing an engine together..
Old Jul 10, 2003 | 07:52 PM
michael O's Avatar
It's called honda bond and the people used tons of it on the engine. It prevents oil leaks.
Old Jul 10, 2003 | 07:53 PM
SIRX's Avatar
you must be referring to the residue left by gaskets. I find it hard to believe that somebody actually glued your motor together (unless the former owner was a real redneck) You must not have torn many motors apart because gasket material is almost always left on machined parts. I use a wire wheel in a drill. works great.
Old Jul 10, 2003 | 08:31 PM
xsellxoutx's Avatar
dude hondabond is the izzle i that stuff, to remove it you can just us a razorblade. my friend tyrone (tybrid perfomance) uses it on almost every gasket, and he was head mechanic at acura for like 6yrs. before opening his shop.
Old Jul 10, 2003 | 08:56 PM
Shawn C's Avatar
In The Garage
hondabond isn't "glue", it's just honda's version of RTV sealant. it's like the black/blue permatex stuff, only for aluminum parts. you can clean it off with emory cloth, and you can get it from any honda dealer. i actually get it from honda motorcycle shops, as they always have it around. for hondabond!
Old Jul 10, 2003 | 09:05 PM
michael O's Avatar
I didn't mean literally gluing it together and this is my first engine but you gotta see the amount of honda bond on here. It's amazing it was everywhere even places its not supposed to be. BTW I know that residue from gaskets is left on motors. "rolleyes"
Old Jul 10, 2003 | 09:09 PM
Rywire's Avatar
Default Re: (22lbGS-R)
There is a couple different types of hondabond(that I have seen), 4 and HT (hi temp). Read the package and get the one that best suits your application. Ryan
Old Jul 10, 2003 | 10:18 PM
USDM 4G VTEC's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">It's called honda bond and the people used tons of it on the engine. It prevents oil leaks.</TD></TR></TABLE>
OH ****
thats the easiest thing to clean
if its Hondabond..... use Carburator cleaner. will clean that stuff right off the bat!
done it many times with my tranny rebuild experiences
Old Jul 10, 2003 | 10:43 PM
michael O's Avatar
Honestly I'm really not sure what it is. I THINK it's hondabond. It's gray and rubbery and stuck on everything.
Old Jul 12, 2003 | 08:19 AM
baytall79's Avatar
that would be the one
susu1632
Honda CR-V & Element
Dec 2, 2017 01:09 PM
smithenhiven
Classic Hondas
101
Oct 21, 2017 11:25 PM
Mrpagani
May 13, 2013 05:07 AM
crzy1208
Jan 23, 2013 03:03 PM
