Is JB weld a safe alternative to regular weld?? Com'on how many have used it? :)
Old Jul 10, 2003 | 06:15 PM
racinskittle's Avatar
Default Is JB weld a safe alternative to regular weld?? Com'on how many have used it? :)
I was thinking about using JB weld for the end tanks on my IC.
Will this work? I will only be boosting 8psi at the max.
Who has used it here??? Any problems?
Also, how bout for the BOV as well? Will it work?
for ghetto weld???
Dan
Old Jul 10, 2003 | 06:25 PM
siboi18's Avatar
Default Re: Is JB weld a safe alternative to regular weld?? Com'on how many have used it? :) (racinskittl
I would suggest welding it. It will hold way more than jb weld can. Plus it will look better than having gunk showing.
Old Jul 10, 2003 | 06:28 PM
romeo619romeo's Avatar
wont work for blow off flange
Old Jul 10, 2003 | 06:57 PM
Alright, Great thanks. Ill have it welded than
Old Jul 10, 2003 | 07:10 PM
Old Jul 10, 2003 | 07:19 PM
stierhund's Avatar
Welding is always better
Do you have a cetaline(sp?) torch? (High heat)
Use coat hanger wire (steel) or go buy aluminum wire. Heat the FMIC where you want to lay the wire and then aly into it with the torch, holds great, looks great.
But check to see if your FMIC is steel or aluminum, most likely aluminum. But im no expert on that.
Old Jul 10, 2003 | 07:32 PM
I have a starion i belive it's aluminum
Old Jul 10, 2003 | 07:35 PM
Old Jul 10, 2003 | 07:43 PM
intercooelrs being steel? wow
Old Jul 10, 2003 | 07:44 PM
hatchback19's Avatar
A friend of mine had JB weld holding together his FMIC on his DSM @ 18psi.
Old Jul 10, 2003 | 07:45 PM
Old Jul 10, 2003 | 07:46 PM
Old Jul 11, 2003 | 06:57 PM
fed integ's Avatar
i have a starion intercooler and i made custom end tanks. am useing metal bond
to hold the end tanks to the intercooler core. thus far i have no problems.....my car has been running boost for almost 2 years.
93 integra
84 mil
abes sleeves
9:0 je piston, eagle rods
stock gsr head
t3-t4 57 trim turbo.
Old Jul 11, 2003 | 07:38 PM
Sweet thanks a lot
Old Jul 11, 2003 | 07:55 PM
b16ahybrid's Avatar
I used jb weld to add two vacuum/boost ports to my charge pipe. I use one for my btm and the other for my wg. They hold up just fine for me..
Old Jul 11, 2003 | 09:06 PM
markdman's Avatar
jb weld melting point is 600 degrees F
Old Jul 11, 2003 | 09:21 PM
Blowensi's Avatar
Default Re: (markdman)
jb weld sucks but you can goto a marine shop they have some stuff 10 times stronger and more heat resitant i for get what its calle dbut all marine shops carry it its to fix anything aluminum.but works just like jb weld
Old Jul 12, 2003 | 04:36 AM
ross1459's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stierhund &raquo;</TD></TR><TR><TD CLASS="quote">Welding is always better
But check to see if your FMIC is steel or aluminum, most likely aluminum. But im no expert on that.</TD></TR></TABLE>
it's oxy-acetyline.
don't ever use coat-hanger wire for welding. it WILL crack. JB weld should hold i guess. i've never used it on aluminum so i wouldn't know.
Old Jul 12, 2003 | 06:33 AM
Gerst240's Avatar
Default Re: (Blowensi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blowensi &raquo;</TD></TR><TR><TD CLASS="quote">jb weld sucks but you can goto a marine shop they have some stuff 10 times stronger and more heat resitant i for get what its calle dbut all marine shops carry it its to fix anything aluminum.but works just like jb weld
i think what your talking about is the PC products they make jb weld look like play dough. What your looking for is called pc metal it will do the job for you it can be found at a local home depot or hardware store.
http://www.pcepoxy.com/puttyepoxies.htm#
Old Jul 12, 2003 | 11:52 AM
Default Re: (Gerst240)
Wow, that looks like it will work. Thanks if I dont end up getting a welder, im gonna use that.
Thanks for the help
Dan
Old Jul 12, 2003 | 04:27 PM
ltho1998's Avatar
JB weld tensile strength (from JB weld website): 3960 lbs/psi.. assuming you have a good adhesion surface.
Steel weld tensile strength: 90,000 lbs/psi.. and welds actually form metallic bonds with the surface.
So judging from this a steel weld is 22x stronger than steel.
Is it worth it to weld? YES, boost leaks suck and they will end your turbo in a heartbeat.
Old Jul 12, 2003 | 07:47 PM
Sinner's Avatar
heres my story.
I have a JB welded
a Greddy type S bov to a ford probe plastic bov pipe.
two oil pans one alumium and a steel one. And i might do another jb weld job on another one.
the only problem I've had was with the BOV I broke it off once but I was pulling really hard on it like an *** trying to move somthing.
Nick
Old Jul 12, 2003 | 10:55 PM
sporkcrx's Avatar
Default Re: (Sinner)
On my buddies sr20 swap the stock intercooler pipe was cracked all the way around. We jb welded that bitch up good! It's been holding 10psi fine so far.
turbotime
Welding / Fabrication
Apr 15, 2006 12:14 AM
LShatchie
May 9, 2005 09:56 PM
Bantam
Nov 26, 2004 08:56 AM
cdog19
Feb 3, 2004 10:39 AM
Greaser
Mar 17, 2003 11:09 AM
