check engine light just came on???
Old Jul 10, 2003 | 05:34 PM
99TegLS's Avatar
Default check engine light just came on???
Hey guys. I've only had my 99teg for 6months and the check engine light just came on. The car is stock for now since I have no cash, driving conditions are normal except for some hard accelerating here and there... Any ideas before I call the shop? Thanks for your help.
Old Jul 10, 2003 | 05:51 PM
Pollux's Avatar
Default Re: check engine light just came on??? (99TegLS)
Just means you need scheduled maintenance, you can turn off the light with a botton under the dash near your right knee if your driving. YOu can feal it with your finger, just push and hold.
Old Jul 10, 2003 | 05:54 PM
99TegLS's Avatar
Default Re: check engine light just came on??? (Pollux)
You are thinking about the "maintinence required" indicator. Just checked it out. The check engine light has no button to turn it off. Any other ideas guys?
Old Jul 10, 2003 | 06:24 PM
romeo619romeo's Avatar
go to your passenger side.. look undere the dash area.. where the ECU is at.. you have to remove the cover.. you will see a green plastic thing with a plug going in it.. remove the plug.. get a piece of metal to stick it in and loop it on the otherside of the wire.. hold it there.. now look at the flashing check engine .. quick pulse are 1.. long pulse is 10
Old Jul 10, 2003 | 06:30 PM
99TegLS's Avatar
Default Re: check engine light just came on??? (romeo619romeo)
Thanks for the info on a remedy to fix it, but any ideas as to what could be causing the light to come on? Any frequent problems with the teg check engine light? Anyone have an idea as to what could be causing the light to come on?
Old Jul 10, 2003 | 07:23 PM
xteg95's Avatar
read what remeo said...when you do that it will explain what is causing your CEL to go off.
91civicmaine
Mar 16, 2006 09:37 AM
pec pec
Jan 31, 2006 07:46 PM
keprunited8
Jan 30, 2005 01:40 PM
Dohc99tegLS
Dec 18, 2003 10:20 AM
Silverhatch
Jun 15, 2003 10:24 AM
