check engine light
Old Dec 17, 2003 | 10:55 PM
Dohc99tegLS's Avatar
Default check engine light
i have a 99 integraLS and my check engine light has been on fo a month now, what can i do or what do i check out to fix it?
Old Dec 17, 2003 | 11:05 PM
six_speed's Avatar
Default Re: check engine light (Dohc99tegLS)
1.if you look under the dash of the passenger side, underneath the glove box to the right you should see two wires going into a yellow plug in a rubber housing.
2.Pull the yellow plug out and get a paper clip or any metal piece and make a U shape.
3.stick it in the two opening.
4.put the key in and put it on position.
5.you should see the check engine light flash.
6.count as it flashes. there's going to be long flashes and short ones.
come back and tell us.
btw the yellow thingy is call a service connector.
ohh and if you just want to get rid of the engine check light for now or future occurence.
just remove the battery's negative terminal and leave it hanging for a few mins and strap it back on.
Old Dec 17, 2003 | 11:06 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: check engine light (Humping_dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">1.if you look under the dash of the passenger side, underneath the glove box to the right you should see two wires going into a yellow plug in a rubber housing.
come back and tell us.</TD></TR></TABLE>
Exactly. Long flash =10 short = 1.
So, 2 long, 3 short= 23.
Old Dec 18, 2003 | 10:20 AM
What do the flashes mean? if i take off the negative on the battery do i do it while the car is off or on?
aspire
Jun 28, 2010 10:49 AM
str8JDMteggy
Sep 24, 2006 08:42 AM
91civicmaine
Mar 16, 2006 09:37 AM
99TegLS
Jul 10, 2003 07:23 PM
Silverhatch
Jun 15, 2003 10:24 AM
