Sedan rear seat removal?
Did a search but only found How-to's for hatches. I need to know how to remove the rear seat in an 89 Civic sedan. The key to unlock the backrest is missing.
You can go in the trunk and find a cloth strap to pull down on. That will release the back of the seat so you can push it forward. There is one bolt behind the middle of the lower part of the seat that scews down to the floor. Remove that and pull the back of the lower seat up. The front hooks of the lower seat come out when you have the back lifted all the way up.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">You can go in the trunk and find a cloth strap to pull down on. That will release the back of the seat so you can push it forward. There is one bolt behind the middle of the lower part of the seat that scews down to the floor. Remove that and pull the back of the lower seat up. The front hooks of the lower seat come out when you have the back lifted all the way up.
HTH
</TD></TR></TABLE>Dumb DSL went out. Anyways, I remembered about the strap after looking in the trunk for a way to take the seat out. Brain fart.
HTH
sageuvagony
Dec 25, 2008 12:54 PM
