hybrid cooling question
ok ive had the h22 in my 5th gen for a year and a half now .....my question is my temp gauge has never moved.......
is there any diff between the lude rad and the accord rad...it gets dam hot under there ...but i havent done a thermstat yet ....
would the spoon thermo switch and thermostt be enough to bring down the temp or should i just get and aftermarket rad
the accord radiators are fine as long as they flow like they were meant to........it's not like swapping from a 1.6 to a 2.2 in a civic....the accord has an engine that is just as big, and the cooling systems are sufficient to say the least....now that said, it wouldn't hurt to have it run cooler, except that maybe your heater won't be as hot...but you can also add some water wetter to it too.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">ok ive had the h22 in my 5th gen for a year and a half now .....my question is my temp gauge has never moved.......
would the spoon thermo switch and thermostt be enough to bring down the temp or should i just get and aftermarket rad </TD></TR></TABLE>
anything you listed would help the cooling system
do your thermostat first and flush the radiator, see how that works first
ok ...ill get on tht first ...makes sence lol
now if im not mistakin at canadian tire (hold the comments it like pep boys...kinda)
they offer 2 different thermostats...one for winter and one for summer .....different tems for each could be a welfare spoon thrmo...
but i hate not buuying honda parts ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizzbob7 »</TD></TR><TR><TD CLASS="quote">now that said, it wouldn't hurt to have it run cooler, except that maybe your heater won't be as hot...but you can also add some water wetter to it too.....</TD></TR></TABLE>
Dude, are you sure about what you are saying?
First he needs to check with some real gauge that his engine is working hotter than what it should be, in case he is he should try to lower temps with what he said, but if he isn't maybe just wraping his header may help reduce underhood temps.
The engine needs the temp to operate, the coolder it is, the more the bores wear out, so be carefull when you say what you just say cuz maybe a nOOb might think that cooler engine means more power and do all what he can to reduce his temps and end up with an engine that is slowly eating itself up.
Sorry for the rant, not trying to insult or anything
the water wetter idea is actually good, off course if that things really does what the manufacturer says
water wetter does work. i dont speak on first hand expierence but a friend with b16 1st gen swap had his temp needle drop about 1/8th after using it.
It's kinda weird that you meantion that, cuz i know is true in some cars more than others, for example, my dads galant (4G63 non turbo high comp.) the underhood temps are soo high that the hoses (mostly coolant) often get hard and break from the temps.
So my advice is, get gauge and wrap your header/manifold on it and see the temps, let us know how it was.
Modified by GZERO at 4:58 PM 7/11/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">water wetter if you ask me is a crutch that will keep you going til you can fix the problem. </TD></TR></TABLE>
All though not necessary, I would recommend a bottle of water wetter at every coolant change. The data does seem to indicate lower coolant temps with it, and it most likely isn't going to hurt cooling performance. $12 every year or two...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">thermo tec do make some nice header wrap and silver heat wrap.
I'd like to clarify for newbies that this would reduce under-hood temps but probably doesn't do much for coolant temp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorH22 »</TD></TR><TR><TD CLASS="quote">I'd like to clarify for newbies that this would reduce under-hood temps but probably doesn't do much for coolant temp.</TD></TR></TABLE>
True, but he stated that the temp gauge has never moved, but the underhood temps are hot as hell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">my question is my temp gauge has never moved.......it gets dam hot under there</TD></TR></TABLE>
i think he knows. He also learned that he should get a gauge to really verify that the engine is running hotter (which i doubt).
Now, what he states (that the underhood temps are hotter) i've seen it and it hapends a lot to older cars, i don't know why, but is true, maybe because the heat deflectors get old or i don't know why.
What do you guys know about this?
yes it does get hot....i cant even touch my strut tower bar......that malk any sence.....mabye just do to the fact that there isnt a whole lot of room under there .......
ps ive ownd 3 rx7s and this is right around the same heat wave when i opened the hood on the rx7........(lol i had the hood up a lot with those cars heheh )
Terry Miller
Jun 23, 2014 02:04 PM
diyer
Sep 29, 2008 02:36 PM
