Would a B16A2 block work with an ITR crank?
Old Jul 10, 2003 | 11:35 AM
umar456's Avatar
Default Would a B16A2 block work with an ITR crank?
just wondering. thanks in advance.
Old Jul 10, 2003 | 12:45 PM
TECH43 RACING INC.'s Avatar
Default Re: Would a B16A2 block work with an ITR crank? (umar456)
easiest thing to do...would be to use the b16a rod (which you have to narrow the big end to fit the crank) and get a custom piston made to move the wrist pin up. the rod ratio will be decreased by the increased stroke...but its the cheapest way to go. another option is to make a custom rod combined with a custom piston. better r/r, but more expensive. i would reccomend using the itr crank/rods/pistons.....and installing them in a ls block. ls block is the same as b16 with the exception of the oil squirters and deck height..and you have to run a oil line to feed oil to the head to operate vtec. the ls block has the same deck height as the type r....so it will make the same hp numbers and run just like a type r.
Old Jul 10, 2003 | 05:39 PM
H25's Avatar
H25
Default Re: Would a B16A2 block work with an ITR crank? (TECH43 RACING INC.)
thats the right way to aproach that. or you can just get a type r block. you will spend less money and have alot less down time. dont get too ahead of yourself, getting too wrapped up in a project might get you in over your head real fast. just my 2 cents.
Old Jul 10, 2003 | 05:45 PM
len's Avatar
len
Default Re: Would a B16A2 block work with an ITR crank? (LuckyRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LuckyRacing &raquo;</TD></TR><TR><TD CLASS="quote">thats the right way to aproach that. or you can just get a type r block. you will spend less money and have alot less down time. dont get too ahead of yourself, getting too wrapped up in a project might get you in over your head real fast. just my 2 cents. </TD></TR></TABLE>
I couldn't agree more.
Old Jul 10, 2003 | 06:16 PM
eddiecut's Avatar
Default Re: Would a B16A2 block work with an ITR crank? (len)
trust me, dont get in over your head, takes along time or alot of money to try and get out of a situation like that, it sucks!
Old Jul 10, 2003 | 07:45 PM
umar456's Avatar
Default Re: Would a B16A2 block work with an ITR crank? (eddiecut)
thanks for the reply you guys. i really appreciate your opinion.
Old Jul 10, 2003 | 08:05 PM
romeo619romeo's Avatar
sell that b16 block and get a b18c
Old Jul 10, 2003 | 08:18 PM
umar456's Avatar
Default Re: Would a B16A2 block work with an ITR crank? (romeo619romeo)
how much do you think i can get for a b16A2 block with 52k miles on it?
Old Jul 10, 2003 | 09:08 PM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umar456 &raquo;</TD></TR><TR><TD CLASS="quote">how much do you think i can get for a b16A2 block with 52k miles on it?</TD></TR></TABLE>
um... about $200.
Old Jul 11, 2003 | 12:13 AM
Default Re: Would a B16A2 block work with an ITR crank? (allmtr)
i've got custom pistons if you are interested...heres the deal...i designed these a while back..and have them running..work great. they are arias. 85mm wrist pin moved up to fit in a b16a block, with ls crank and rods. super light 255 grams!. .708 wrist pin, so you must bush your rods from .826 to .708 (appx 80.00) .100 wall thick. 11.5 to 1 with b16a head w/ 43cc chamber (unmilled). 1/1.2/2.8 rings. custom buttons to support rings. super short skirt. .003 piston to wall clearance. the ultimate sleeper/streetrace piston. you are stuffing a 4mm overbored ls/1mm overbored b20....into a b16a block..2.0 b16a with a 1.54 r/r.....and no one will know!!!!.....i have guys making around 230 at the tire on pump gas with skunk stage 2's.....stock ecu.....through a muffler. will post pics if someone is serious. 650.00
Old Jul 11, 2003 | 08:43 PM
ttt
Old Jul 12, 2003 | 03:06 AM
umar456's Avatar
that sounds like a great deal but my car is also my daily driver so i cant have it at the shop for a long time.
Old Jul 12, 2003 | 08:58 AM
mmuller's Avatar
Mad Scientist
itr crank in b16 in utterly pointless, just get a b18 block
Old Jul 12, 2003 | 10:04 AM
ALLMTRWHORE's Avatar
Default Re: Would a B16A2 block work with an ITR crank? (mmuller)
if you r main concern is just to go sleeper then like lucky and others have said it requires work! you have enough info here to get your feet wet into this. sounds like a coll sleeper set-up which I have seen many times! but it always cool for the guys oh all you have is a b16 hehe! good luck bro keep us posted on more questions you may have!
Old Jul 12, 2003 | 11:01 AM
TRAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">i've got custom pistons if you are interested...heres the deal...i designed these a while back..and have them running..work great. they are arias. 85mm wrist pin moved up to fit in a b16a block, with ls crank and rods. super light 255 grams!. .708 wrist pin, so you must bush your rods from .826 to .708 (appx 80.00) .100 wall thick. 11.5 to 1 with b16a head w/ 43cc chamber (unmilled). 1/1.2/2.8 rings. custom buttons to support rings. super short skirt. .003 piston to wall clearance. the ultimate sleeper/streetrace piston. you are stuffing a 4mm overbored ls/1mm overbored b20....into a b16a block..2.0 b16a with a 1.54 r/r.....and no one will know!!!!.....i have guys making around 230 at the tire on pump gas with skunk stage 2's.....stock ecu.....through a muffler. will post pics if someone is serious. 650.00</TD></TR></TABLE>
sounds cool
Old Jul 12, 2003 | 04:07 PM
dfoxengr's Avatar
easiest thing to do..search
i hate import cars
Oct 26, 2007 07:27 AM
Teamdiesel
Apr 14, 2007 05:31 PM
Topdawgg
Dec 20, 2005 04:19 PM
g2teg
Apr 8, 2002 03:38 PM
