Thought I'd show my setup since it leaving home next week
Old Jul 10, 2003 | 10:48 AM
abraunb16's Avatar
New User
Default Thought I'd show my setup since it leaving home next week
My baby in all it's glory. Does anyone know how to actually show the images vs just posting the website they are hosted on? If someone can help me out I'd greatly appreciate it. Enjoy!
http://www.ratemybedroom.com/carparts/af_guage.jpg
http://www.ratemybedroom.com/c...t.jpg
http://www.ratemybedroom.com/c...e.jpg
http://www.ratemybedroom.com/c...i.jpg
http://www.ratemybedroom.com/c...r.jpg
http://www.ratemybedroom.com/carparts/fmic.jpg
http://www.ratemybedroom.com/carparts/intake.jpg
http://www.ratemybedroom.com/carparts/radio.jpg
http://www.ratemybedroom.com/c...c.jpg
http://www.ratemybedroom.com/c...p.jpg
Old Jul 10, 2003 | 11:37 AM
eddiecut's Avatar
Default Re: Thought I'd show my setup since it leaving home next week (abraunb16)
[img]hit the image button and then put the url in betwee[/img]
Old Jul 10, 2003 | 12:55 PM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (eddiecut)
How in the heck did you do that. Man I need to a class on this or something. Any help is appreciated. Later Allen
[IMG][/IMG]
Old Jul 10, 2003 | 12:56 PM
mos's Avatar
mos
guess I cant do it either.
edit: Oh wait there it goes. This aint all of em tho.
Looks great!
Modified by mos at 2:10 PM 7/10/2003
Old Jul 10, 2003 | 01:07 PM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (mos)
Nevermind you got it! Now how did you do it? So what do you think about the setup. I kinda fancey it!
A couple double ups, but atleast you got it.
Just incase anyone cares, here's the run down:
B18A Block
B16 Head
Step decked
Sleeved
83mm JE 9.5:1
Crower Rods
ARP rod bolts
GSR Bearings
Micropolished crank
Balanced/Blued
B16 oil pan
B16 oil pick up
Stock head
Stock Valves
Portflow inner springs
Portflow Ti retainers
GSR cams
ARP head studs
AEM cam gears
AEM fuel rail
RC 800 cc injectors
B&M FPR w/gauge
Stock intake mani (4 drilled vacuum sources on the back)
Stock throttle body
MaxRev exhaust mani
T03/T04E Garret(a/r .63, a/r .60 compress .57 trim, stage 3 wheel)
Custom 2.5 inch piping
Custom intake piping
XS intercooler(20x10.75x3)
3 inch down pipe and custom exhaust rear passengerside exit
MSD 6AL
Blater 3 coil
MSD cap
NGK plug wires
NGK BRK7Es
AC Delco 3 bar map sensor
Balist Resistor pack
Walbro 255 intake fuel pump
Misc steel braided lines
Misc Earl's fittings
Greddy Profec B
Greddy timer
Greddy 60 mm boost
Greddy 60 mm EGT
Greddy60 mm A/F
Stock cooling system(working good so far)
ES lower motor mounts
HASport driverside drag mount
No A/C
No Powersteering
No Cruise Control
LS tranny w/Quaife LSD
ACT Xtreme w/6 puck
Stock Flywheel
Stock axles
AEM Plug n Play EMS(semi tuned)(296 whp & 232 ft lbs on 8 psi)
All stuffed in a 99 Si coupe!
Modified by abraunb16 at 2:19 PM 7/10/2003
Old Jul 10, 2003 | 01:45 PM
I Like Boost's Avatar
Tight setup
Old Jul 10, 2003 | 02:38 PM
int3gra's Avatar
where is your setup leaving to? selling it?
Old Jul 10, 2003 | 06:21 PM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (int3gra)
Yeah, just got paid in full, so dropping it out tomarrow. I thought some of the H-T folks would like to see my stealth bomber, nothing like a stock looking Si. Black intercooler and no visalbe gauges. Just a V8 sounding exhaust. Cars going back to stock then getting sold or traded in. It was fun while it lasted and I'll always have the memories of seeing LS1's and other 8's in the rearview. Oh the memories!
Old Jul 10, 2003 | 06:39 PM
EVOLMTR's Avatar
nice setup
Old Jul 10, 2003 | 08:02 PM
TRAY's Avatar
Default Re: Thought I'd show my setup since it leaving home next week (EVOLMTR)
In your mod list you stated that you drilled some vacuum sources in the back of your intake mani. What size fittings did you use and is this safe? Thanks!
Old Jul 10, 2003 | 08:17 PM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (TrayDay2K1)
If you look at the 5th picture . I couldn't think of a reason why it wouldn't work or how it could cause any problems. It was 1/8 inch pipe threaded male ends. I picked out 2 smaller diameter ones to fit the smaller hoses for the boost controller and BOV, then 2 larger for the Gate and Black Profec B box.
If you look at the back right side of the mani you can see a couple vacuum lines, that's were I drilled and tapped. I used JB Weld on the threads when I installed the male pieces. Make sure when you drill you get the angle right so the fittings will be flush with manifold surface. Later Allen
Old Jul 10, 2003 | 09:23 PM
SiRkid's Avatar
Old Jul 10, 2003 | 11:09 PM
ScrapinSi's Avatar
have a pic of the exhaust dump?
Old Jul 11, 2003 | 12:12 AM
15psi of fun's Avatar
it looks good but why only 9psi
and yes i just got back from AZ it is to HOTTTTTTTTT!!!!!!!!!! out there
Old Jul 11, 2003 | 05:39 AM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (EFrollingout)
You kinda answered your own question. 1.) It's hot here 2.)AEM is picky and 3.)I'm a ***** and didn't want to experiment with a unit that I wasn't a pro at.
No pic of the exhaust, I can snap one tonight when it's on the rack. Later Allen
Old Jul 11, 2003 | 12:52 PM
TRAY's Avatar
Thanks! Im prob gonna do that on my setup..
Old Jul 11, 2003 | 01:23 PM
sporkcrx's Avatar
So what car are you planning on getting next?
Old Jul 12, 2003 | 09:55 AM
abraunb16's Avatar
New User
Default Re: Thought I'd show my setup since it leaving home next week (sporkcrx)
A bucket with A/C to drive daily! Then start a weekend warrior project, I've been looking at Talon/Eclipse, Typhoon/Syclone, Conquest/Starion, Ford Merkur, Supra old & new, Grand National/TTA, 2.5 Subie w/RA swap, 240SX w/swap, Datsun 310 w/swap and the list goes on. Just want to do something different and have it to play with whenever I want and not have to worry about it everyday. Plus my kids wouldn't have to be hauled around in a hot car with no A/C. Later Allen
uNVmyEJ8
Apr 13, 2009 02:39 PM
c1_sleeper
Mar 10, 2007 11:08 PM
CaMiKaZi
Audio / Security / Video
Sep 4, 2003 05:10 AM
