Pics of my DA and ls/vtec setup!
Rear angle view
Front angled view, 15" bronze rota slipstreams, tc spoiler carbon fiber hood
Full angle view
Rear angle view
Shaved rear bumper WRX style... I didn't quite capture it hahah... Notice the tie bar and the black stock muffler bolted on for now.
LS/VTEC B16 head milled .030, GSR cams, crower springs/retainers/ss valves, polished silinoid, DC 421
Skunk2 cam gears, ITR intake manifold, b&m fpr
B16 S1 tranny with ACT 6pad, 12lb flywheel matted to a B18A block, ITR .25over pistons and decked .008
Simple interior, stock radio and all, forgot to show fully gutted rear and upper tie bar
Modified by VtecDA9 at 7:45 PM 7/10/2003
Full angle view
Rear angle view
Thanks fellas...Need to get another 6pad disc before the 12th or I ain't going to fontana... want to run with gsr fuel pump too, but not enough time... Love the motor though...
Just a few questions..
Did you do anything to your bottom end? I'm definately not flaming, but i want to lsvtec my car, and i dont want to do anything special to the bottom end, AND i want the bitch to last, lol.
What color are those slipsteams in the front?
Can you try and post a picture of your gutted rear interior!
btw, nice car, reminds me alot of my car, minus the b16 head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 »</TD></TR><TR><TD CLASS="quote">Just a few questions..
BLOCK GUARD, NEW HEAD GASKET!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal »</TD></TR><TR><TD CLASS="quote">That is an ugly steering wheel, nice car other wise.</TD></TR></TABLE>
WTF....the man has a built lsvtec and your complaining about an oem steering wheel. put your money under the hood where it belongs then do free mods like steering wheel, shifter and cosmetics. Car looks good man
Yeah... not much more I want to do to the exterior other than jdm side molidings, 1 piece headlights, and add rear slipstreams.
The motor pulls damn strong... I had too much fun with it for a lil and that's why my old 6puck wore out, but chirping into 3rd and pulling with the S1 cable tranny felt good. I'm pretty satisfied considering the head has stock GSR cams, although on full crower vavletrain. Soon as I get sk2 stg 1 cams and VAFC tuned, I believe the car will be pretty decent on the street with the simple style I like
The block work consist of hot tank, bored .25 over for ITR oversizd pistons, micropolished crank journals, resized rods notched for gsr rod bearings, fully balanced bottom end rotating assembly, gsr oil and ater pumps, new honda seals, bearings, and rings. The block spins clean to 8400, but no need to even go that high yet on gizzer cams.
Modified by VtecDA9 at 7:55 PM 7/10/2003
Although I'm not a big fan of the LS/V Hybrid, it looks pretty dam nice. Only thing I have to admit never seeing b4 is carbon fiber hood and you dont have clear corners
not a big deal though, sound like you have most of the performance mods you need and you'll be doing the exterior **** soon. post more pics when you do. looks good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr »</TD></TR><TR><TD CLASS="quote">
WTF....the man has a built lsvtec and your complaining about an oem steering wheel. put your money under the hood where it belongs then do free mods like steering wheel, shifter and cosmetics. Car looks good man</TD></TR></TABLE>
I told him nice car. Yes I am complaining about an OEM wheel, so you like it I assume,
by the way, your sig-
cheap and reliable wont be fast
cheap and fast wont be reliable
reliable and fast wont be cheap
Wasn't that on the shop wall in th F&F outside
Hey, saw your car on g2ic, but it's down right now. Nice setup man, who did the install for you. I did the same thing a month ago and I have never regretted it. My bottom end is not done yet, hopefully soon though since my motor is blowing lots of blue
How do you like your S1? I'm afraid of its 5th gear being too short, I'm opting for the Ls 5th instead... since I do lots of highway driving.
Are you running girdles at all? Did you shotpeened your rods? How sure are you that the motor will be good til 8400RPM? Would you mind clarifying on those since I'm still debating.... TIA
PS. Very nice car BTW, always liked the Captiva Blue :D
Nice da have not see you around pasadena before, Mabie i will see you at fontana on the 12th
. We cant run, Nice set up btw lates...
Thanks man... Well for the S1 tranny, i had a LS 5th gear installed... i like it...
No girdle, stock rods, stock bolts... but resized rods, renotched for gsr bearings, fully balanced bottom end rotating assembly... I've spun it to 8400 quite a bit and really pushed it 8400,8000, 7800 on the street after long driving plenty of times to test it... motor runs quiet and smooth... love this thing...oil levels are good, no leaks... I researched a lot for the truths behind the ls/vtec.. one person to note... ie) jeff at IB respectable builder... and you'll find stock rods and bolts to be fine to 8500 if you do everything correctly.... balance, balance, balance... everything down there...
Modified by VtecDA9 at 10:16 AM 7/11/2003
Combustion Contraption
11
Oct 7, 2003 07:29 PM
