matching hyperwhites on clear corners? Anyone have problems?
Does anyone have a problem matching the color of the turnsignal and constant two bulbs in the clear corners of your teg?
It seems when the turn signal is on, the front bulb gets bright enough to perfectly match the sides, but during normal driving, the color difference is very noticeable.
I was thinking of wiring the front one to be constant on, but before I do - Is this a real problem or do I have wrong/mismatched hyperwhite bulbs?
Thanks
Rage
Thanks
Rage
ah..why bother you so much, it just a freakin light.
just throw in some hyper white blub and call it finished.
maybe it just me
maybe it just me
maybe you don't understand.
I have hyperwhite bulbs in. They don't match - same brand, same color.
I'm wondering if other ppl have the same problem, because the front facing bulb has two voltages/wattages.
I've seen people run without one light and i was wondering if this was the reason.
-Rage
-Rage
Just make it so the hyperwhite turnsignals only come on when you turn.
Just put tape over one of the bulbs on the turn signal bulb and wala. (at least that's what you can do on turnsignal bulbs.)
Quetzolcotl
11
Dec 9, 2003 11:42 AM
